Coding for airbags on comfort seats
pete62
Re: Coding for airbags on comfort seats
Post by pete62 » Mon Mar 06, 2017 3:48 pm
With0473114
Post by Shoppinit » Mon Mar 06, 2017 4:46 pm
Try coding 0471114 (I understand this is the donor car's coding).
Then clear the DTC.
Reset the seat occupancy.
Do the basic settings for the seat occupancy.
See what happens.
Post by Shoppinit » Mon Mar 06, 2017 5:06 pm
I think with 047114 the module is expecting a cut-off switch for the passenger side airbag. You know, the one you put your key in when you have a rear facing baby seat.
Do you have one?
Does the donor car?
pete62
Post by pete62 » Mon Mar 06, 2017 5:09 pm
Mine doesn't and I've pm'd the owner of the donor car to see if his does
Found this
pete62
Post by pete62 » Mon Mar 06, 2017 5:11 pm
Car is on charge now so giving it a rest until battery is back to strength.
Once it's charged will try again
Post by Shoppinit » Mon Mar 06, 2017 5:17 pm
Yeah, I saw that. Doesn't really give us much information. Doesn't seem to affect the occupancy issue. But might explain why you get the switch fault codes when you use the donor cars coding (assuming the donor car has one).
Also, I have read that you need to cycle the ignition after resetting. So maybe do this with your original coding of 0470114:
Then clear the DTC.
Cycle the ignition
Clear DTC
Post by Shoppinit » Mon Mar 06, 2017 5:20 pm
Also, you might need to set adaption channels.
I think you need to set adaptation channels 003 and 004 to active because you now have side airbags.
Try the previous post first, then maybe set the adaptation and try it again if it doesn't work.
pete62
Post by pete62 » Mon Mar 06, 2017 5:40 pm
Then clear the DTC.
Cycle the ignition
Clear DTC
What do you mean by do the basic settings for seat occupancy?
Post by Shoppinit » Mon Mar 06, 2017 6:03 pm
pete62
Post by pete62 » Mon Mar 06, 2017 6:09 pm
Hmm ok
That table doesn't make sense to me as for instance my code ends in 4 but unless I'm interpreting it wrong the only options for the 7th digit is 2 or 7?
Post by Shoppinit » Mon Mar 06, 2017 6:11 pm
Unfortunately the table isn't complete. Hence the limited usefulness. It's pretty much what you posted up.
I posted that link to show the basic settings.
pete62
Post by pete62 » Mon Mar 06, 2017 6:42 pm
Donor car had key operated passenger airbag mine hasn't got that.
Post by Shoppinit » Mon Mar 06, 2017 6:49 pm
That explains the difference in coding then. I now believe you need to keep your original coding.
pete62
Post by pete62 » Mon Mar 06, 2017 10:23 pm
Mr Shoppinit
You might
Just
Be a
Ferkin
Genius!!
Post by Shoppinit » Tue Mar 07, 2017 9:58 am
Obvs.
Is it sorted then?
Users browsing this forum: No registered users and 222 guests
