Coding for airbags on comfort seats
Re: Coding for airbags on comfort seats
With0473114
Try coding 0471114 (I understand this is the donor car's coding).
Then clear the DTC.
Reset the seat occupancy.
Do the basic settings for the seat occupancy.
See what happens.
Then clear the DTC.
See what happens.
I think with 047114 the module is expecting a cut-off switch for the passenger side airbag. You know, the one you put your key in when you have a rear facing baby seat.
Do you have one?
Does the donor car?
Do you have one?
Does the donor car?
Mine doesn't and I've pm'd the owner of the donor car to see if his does
Found this
Found this
Car is on charge now so giving it a rest until battery is back to strength.
Once it's charged will try again
Yeah, I saw that. Doesn't really give us much information. Doesn't seem to affect the occupancy issue. But might explain why you get the switch fault codes when you use the donor cars coding (assuming the donor car has one).
Also, I have read that you need to cycle the ignition after resetting. So maybe do this with your original coding of 0470114:
Then clear the DTC.
Cycle the ignition
Clear DTC
Then clear the DTC.
Cycle the ignition
Clear DTC
Also, you might need to set adaption channels.
I think you need to set adaptation channels 003 and 004 to active because you now have side airbags.
Try the previous post first, then maybe set the adaptation and try it again if it doesn't work.
What do you mean by do the basic settings for seat occupancy?Shoppinit wrote: ↑Mon Mar 06, 2017 5:17 pmYeah, I saw that. Doesn't really give us much information. Doesn't seem to affect the occupancy issue. But might explain why you get the switch fault codes when you use the donor cars coding (assuming the donor car has one).
Then clear the DTC.
Cycle the ignition
Clear DTC
Hmm ok
That table doesn't make sense to me as for instance my code ends in 4 but unless I'm interpreting it wrong the only options for the 7th digit is 2 or 7?
Unfortunately the table isn't complete. Hence the limited usefulness. It's pretty much what you posted up.
I posted that link to show the basic settings.
Donor car had key operated passenger airbag mine hasn't got that.
That explains the difference in coding then. I now believe you need to keep your original coding.
Mr Shoppinit
You might
Just
Be a
Ferkin
Genius!!
You might
Just
Be a
Ferkin
Genius!!
Obvs.
Is it sorted then?
Is it sorted then?
Users browsing this forum: Zyox and 257 guests
