B7 RS4 cams into B6 S4..?
tartan_rob
Does anyone know if these will fit (I presume so) and what difference if any will they make?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
philipwalker
- 5th Gear
RE: B7 RS4 cams into B6 S4..?
I suspect they will fit however they are £447 ea, I think the labour to fit would be grim due to the timing chains at the rear of the engine. I am sure there is a way to remove the cams without pulling the engine out.
Schrick list cams 272 and a 264 duration for the S4 V8 not sure how the duration compares with the RS4 V8 cams Priced at 390 euros ea
Isn't the S4 engine 5 valves per cylinder and the RS4 4 valve's? Probably talking out my
Schrick make good cams so probably a safer bet.
Mark
philipwalker
- 5th Gear
They are both two vales per cylinder
Ah that was it. I thought the S4 was 4 and RS4 2, but still wrong!
Mark
philipwalker
- 5th Gear
I lied !
The S4 BBK engine has 24 inlet valves and 16 exhaust
The RS4 BNS has 16 inlet and 16 Exhaust
Does that mean I was right?
In the first place...
This I would say means the RS4 inlet cams are a no go and probably also the exhaust cams as the head design must be quite different.
Mark
tartan_rob
Anyone got any links for Schrick cams? I can't find any site with meaningful information.
Ta
Ta
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Indeed where inlet valve 5 is - there is now the FSI Injector... good thinking Mark.
Rob... you set on modding the v8 aint you? Just give it to the americans - they have some crazy voodoo and get mad power out of v8's.
philipwalker
- 5th Gear
Had a read up on Elsa yesterday,
To remove the camshafts "you must first remove the engine and split from the gearbox" makes the job a bit more involving.
tartan_rob
Fcuk that. too much work, I'd rather not go down the serious tuning road again. Don't mind bolting a supercharger on but not into hoofing engine out.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
