B7 RS4 cams into B6 S4..?
tartan_rob
Post by tartan_rob » Sun Mar 11, 2007 9:40 pm
Does anyone know if these will fit (I presume so) and what difference if any will they make?
2017 Kawasaki Z1000
2014 RS6
2014 S1
philipwalker
RE: B7 RS4 cams into B6 S4..?
Post by philipwalker » Mon Mar 12, 2007 10:34 am
I suspect they will fit however they are £447 ea, I think the labour to fit would be grim due to the timing chains at the rear of the engine. I am sure there is a way to remove the cams without pulling the engine out.
Schrick list cams 272 and a 264 duration for the S4 V8 not sure how the duration compares with the RS4 V8 cams Priced at 390 euros ea
http://www.pwmotorsport.com
PW Motorsport
01437 563929
MarkB
Post by MarkB » Mon Mar 12, 2007 10:39 am
Isn't the S4 engine 5 valves per cylinder and the RS4 4 valve's? Probably talking out my :assflash:
Schrick make good cams so probably a safer bet.
Mark
philipwalker
Post by philipwalker » Mon Mar 12, 2007 11:16 am
They are both two vales per cylinder
PW Motorsport
01437 563929
MarkB
Post by MarkB » Mon Mar 12, 2007 11:18 am
Ah that was it. I thought the S4 was 4 and RS4 2, but still wrong!
Mark
philipwalker
Post by philipwalker » Mon Mar 12, 2007 11:30 am
I lied !
The S4 BBK engine has 24 inlet valves and 16 exhaust
The RS4 BNS has 16 inlet and 16 Exhaust
PW Motorsport
01437 563929
MarkB
Post by MarkB » Mon Mar 12, 2007 11:36 am
Does that mean I was right? :boots: In the first place...
This I would say means the RS4 inlet cams are a no go and probably also the exhaust cams as the head design must be quite different.
Mark
tartan_rob
Post by tartan_rob » Mon Mar 12, 2007 12:15 pm
Anyone got any links for Schrick cams? I can't find any site with meaningful information.
Ta
2017 Kawasaki Z1000
2014 RS6
2014 S1
ZeroK66
Post by ZeroK66 » Mon Mar 12, 2007 1:43 pm
Indeed where inlet valve 5 is - there is now the FSI Injector... good thinking Mark.
Rob... you set on modding the v8 aint you? Just give it to the americans - they have some crazy voodoo and get mad power out of v8's.
philipwalker
Post by philipwalker » Tue Mar 13, 2007 9:42 am
Had a read up on Elsa yesterday,
To remove the camshafts "you must first remove the engine and split from the gearbox" makes the job a bit more involving.
PW Motorsport
01437 563929
tartan_rob
Post by tartan_rob » Tue Mar 13, 2007 11:43 am
Fcuk that. too much work, I'd rather not go down the serious tuning road again. Don't mind bolting a supercharger on but not into hoofing engine out.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Users browsing this forum: No registered users and 39 guests
