Rear springs
- kcsun
Rear springs
My car has just returned from the Stealers after its 80k cam belt change and full service
What worries me (as well as the bill) is that I had a broken rear spring - which to be fair they contacted me about and have replaced the pair.
The broken spring was on the rear nearside and a piece approx 60mm long had broken off the end (it was still in the cup)
I was totally unaware of this and the car behaved "normally"
My questions are
Is this common?
Why did it happen?
Was it dangerous or VERY DANGEROUS?
If it is common - should it be the subject of a recall?
Your thoughts
kc
My questions are
Is this common?
Why did it happen?
Your thoughts
kc
philipwalker
- 5th Gear
RE: Rear springs
I have changed a few, the failure is often in the same place as yours, the top part of the coil.
The rear spring is around £75 ea and about a hours work per side to change.
RE: Rear springs
I had this too - quite common I think. I also have not noticed any difference between a broken spring and and a new one. The car still sits quite low at the back with th new springs on. I changed it pronto cos I was off to Europe.
Olly
Olly
RE: Rear springs
Same here. One broken, both replaced, couldn't tell the difference.
- Virdee Autos
- Trader (Expired)
Yep seems to be common on the RS4.
Also quite common on all other makes of cars these days. Merc's are notorious for this especially the A-Class rear ones, and also E-class fronts. Must be the cost cutting!
Virdee Autos ~ 07950-526592
- rsmonkey918
- 2nd Gear
Can only add that it happened to mine- rear O/S - noticed in June when I upgraded the brakes- last 60mm or so and again still in the cup- fracture was difficult to see- MOT boys didn't spot it either!- was going to do the suspension later in the year so simply brought it forward- drove around for a couple of weeks before the Bilsteins showed up- no problems.
Steve
Steve
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
