Rear springs
2.7 V6 30v biturbo - 380 bhp
kcsun
Rear springs
Post by kcsun » Thu Oct 09, 2008 11:55 pm
My car has just returned from the Stealers after its 80k cam belt change and full service
What worries me (as well as the bill) is that I had a broken rear spring - which to be fair they contacted me about and have replaced the pair.
The broken spring was on the rear nearside and a piece approx 60mm long had broken off the end (it was still in the cup)
I was totally unaware of this and the car behaved "normally"
My questions are
Is this common?
Why did it happen?
Was it dangerous or VERY DANGEROUS?
If it is common - should it be the subject of a recall?
Your thoughts
kc
philipwalker
RE: Rear springs
Post by philipwalker » Fri Oct 10, 2008 7:54 am
I have changed a few, the failure is often in the same place as yours, the top part of the coil.
The rear spring is around £75 ea and about a hours work per side to change.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
ollys
RE: Rear springs
Post by ollys » Fri Oct 10, 2008 9:12 am
I had this too - quite common I think. I also have not noticed any difference between a broken spring and and a new one. The car still sits quite low at the back with th new springs on. I changed it pronto cos I was off to Europe.
Olly
SimonC
RE: Rear springs
Post by SimonC » Fri Oct 10, 2008 10:30 am
Same here. One broken, both replaced, couldn't tell the difference.
Jarv
Post by Jarv » Fri Oct 10, 2008 12:23 pm
And the same for me too. Last time it was at MRC a few months back they spotted a broken spring so replaced them both. I'm guessing that it's a combination of the age of the car, dreadful roads and speedbumps.
Mike
Q7
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Oct 10, 2008 6:43 pm
Yep seems to be common on the RS4.
Also quite common on all other makes of cars these days. Merc's are notorious for this especially the A-Class rear ones, and also E-class fronts. Must be the cost cutting!
Virdee Autos ~ 07950-526592
par_s4
Post by par_s4 » Fri Oct 10, 2008 9:01 pm
My S4 Avant currently has the same problem on both rear springs, although it is the lower coil on each which has fractured off.
2000 S4 Avant | Santorin Blue | 710Ns | Short Shift | R8 Replicas | B5 RS4 Brakes
imolas4uk
Post by imolas4uk » Sat Oct 11, 2008 9:34 pm
yeah its really common on all audi`s ,i change loads of em,the powder coating splits or wears away then water gets in corrosion takes place then a hole or a speed bump and thats it pal :audibash:
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
rsmonkey918
Post by rsmonkey918 » Wed Oct 15, 2008 2:08 pm
Can only add that it happened to mine- rear O/S - noticed in June when I upgraded the brakes- last 60mm or so and again still in the cup- fracture was difficult to see- MOT boys didn't spot it either!- was going to do the suspension later in the year so simply brought it forward- drove around for a couple of weeks before the Bilsteins showed up- no problems. :D
Steve
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
