Rear springs
2.7 V6 30v biturbo - 380 bhp
kcsun
Rear springs
Post by kcsun » Thu Oct 09, 2008 11:55 pm
My car has just returned from the Stealers after its 80k cam belt change and full service
What worries me (as well as the bill) is that I had a broken rear spring - which to be fair they contacted me about and have replaced the pair.
The broken spring was on the rear nearside and a piece approx 60mm long had broken off the end (it was still in the cup)
I was totally unaware of this and the car behaved "normally"
My questions are
Is this common?
Why did it happen?
Was it dangerous or VERY DANGEROUS?
If it is common - should it be the subject of a recall?
Your thoughts
kc
philipwalker
RE: Rear springs
Post by philipwalker » Fri Oct 10, 2008 7:54 am
I have changed a few, the failure is often in the same place as yours, the top part of the coil.
The rear spring is around £75 ea and about a hours work per side to change.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
ollys
RE: Rear springs
Post by ollys » Fri Oct 10, 2008 9:12 am
I had this too - quite common I think. I also have not noticed any difference between a broken spring and and a new one. The car still sits quite low at the back with th new springs on. I changed it pronto cos I was off to Europe.
Olly
SimonC
RE: Rear springs
Post by SimonC » Fri Oct 10, 2008 10:30 am
Same here. One broken, both replaced, couldn't tell the difference.
Jarv
Post by Jarv » Fri Oct 10, 2008 12:23 pm
And the same for me too. Last time it was at MRC a few months back they spotted a broken spring so replaced them both. I'm guessing that it's a combination of the age of the car, dreadful roads and speedbumps.
Mike
Q7
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Oct 10, 2008 6:43 pm
Yep seems to be common on the RS4.
Also quite common on all other makes of cars these days. Merc's are notorious for this especially the A-Class rear ones, and also E-class fronts. Must be the cost cutting!
Virdee Autos ~ 07950-526592
par_s4
Post by par_s4 » Fri Oct 10, 2008 9:01 pm
My S4 Avant currently has the same problem on both rear springs, although it is the lower coil on each which has fractured off.
2000 S4 Avant | Santorin Blue | 710Ns | Short Shift | R8 Replicas | B5 RS4 Brakes
imolas4uk
Post by imolas4uk » Sat Oct 11, 2008 9:34 pm
yeah its really common on all audi`s ,i change loads of em,the powder coating splits or wears away then water gets in corrosion takes place then a hole or a speed bump and thats it pal :audibash:
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
rsmonkey918
Post by rsmonkey918 » Wed Oct 15, 2008 2:08 pm
Can only add that it happened to mine- rear O/S - noticed in June when I upgraded the brakes- last 60mm or so and again still in the cup- fracture was difficult to see- MOT boys didn't spot it either!- was going to do the suspension later in the year so simply brought it forward- drove around for a couple of weeks before the Bilsteins showed up- no problems. :D
Steve
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
Users browsing this forum: No registered users and 158 guests
