Rear springs
- kcsun
Rear springs
My car has just returned from the Stealers after its 80k cam belt change and full service
What worries me (as well as the bill) is that I had a broken rear spring - which to be fair they contacted me about and have replaced the pair.
The broken spring was on the rear nearside and a piece approx 60mm long had broken off the end (it was still in the cup)
I was totally unaware of this and the car behaved "normally"
My questions are
Is this common?
Why did it happen?
Was it dangerous or VERY DANGEROUS?
If it is common - should it be the subject of a recall?
Your thoughts
kc
My questions are
Is this common?
Why did it happen?
Your thoughts
kc
philipwalker
- 5th Gear
RE: Rear springs
I have changed a few, the failure is often in the same place as yours, the top part of the coil.
The rear spring is around £75 ea and about a hours work per side to change.
RE: Rear springs
I had this too - quite common I think. I also have not noticed any difference between a broken spring and and a new one. The car still sits quite low at the back with th new springs on. I changed it pronto cos I was off to Europe.
Olly
Olly
RE: Rear springs
Same here. One broken, both replaced, couldn't tell the difference.
- Virdee Autos
- Trader (Expired)
Yep seems to be common on the RS4.
Also quite common on all other makes of cars these days. Merc's are notorious for this especially the A-Class rear ones, and also E-class fronts. Must be the cost cutting!
Virdee Autos ~ 07950-526592
- rsmonkey918
Can only add that it happened to mine- rear O/S - noticed in June when I upgraded the brakes- last 60mm or so and again still in the cup- fracture was difficult to see- MOT boys didn't spot it either!- was going to do the suspension later in the year so simply brought it forward- drove around for a couple of weeks before the Bilsteins showed up- no problems.
Steve
Steve
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
Users browsing this forum: jdp and 80 guests
