alloy bufkin pipe
Steve2003rs6
Re: alloy bufkin pipe
Post by Steve2003rs6 » Wed Mar 10, 2021 7:31 pm
norwichphoto wrote:
Wed Mar 10, 2021 5:54 pm
If any not spoken for I suppose I should consider one for my new project.
Will do
Steve2003rs6
Post by Steve2003rs6 » Wed Mar 31, 2021 9:41 pm
Hi guys. Called in the machine Shop to check on manufacture progress. They had been short on small diameter brass.
Have now got some and machining will start soon.
Following my contacts holidays.
Just thought I would give you all a update.
*Will*
Post by *Will* » Sat Apr 17, 2021 2:33 am
Can someone point me in the direction that I can get one of these from Poland? Thanks! Will
Steve2003rs6
Post by Steve2003rs6 » Sat Apr 17, 2021 8:36 am
Will. Details have been sent to your PM
Just let me know.
Sorry. I replied to your PM before I had read the above message.
mikeklien
Post by mikeklien » Tue May 25, 2021 6:37 pm
And that's when the fun begins....
My Bufkin story started about 6 years ago after dropping the RS off for a MOT & casually mentioning to the garage guys, just as an afterthought, "Oh, while you've got her in, just have a quick look around for a minor coolant leak as I'm losing just a drop every few hundred miles or so, no biggie..."
Ended up 6 weeks later with a not insubstantial bill including new hybrid turbos, race dp's, new head gaskets etc. etc. coz, may as well when the engine's out innit...oh, and a 5 quid Bufkin pipe :shock:
I've heard rumours that Grizz at Unit 20 can change the pipe without an engine pull but it's a big ask.
Good luck :thumbs:
Steve2003rs6
Post by Steve2003rs6 » Tue May 25, 2021 6:58 pm
Mikeklien. I am at unit 20 now for 2 days. I will ask grizz if this can be done.
Ps I chased up the machine Shop last week to see how they are getting on with the bufkin pipes.
Waiting to hear from them.
G pat
Post by G pat » Tue May 25, 2021 9:38 pm
Mines going to qst in Hayward’s Heath for the bufkin pipe to be replaced, when the parts arrive ( on back order obviously). Kim Collins at qst says they will be doing it with the engine in.
Steve2003rs6
Post by Steve2003rs6 » Tue May 25, 2021 10:33 pm
That’s great to know.
Bit of a boost knowing the engine can remain in situ.
Weiß-sechs
Post by Weiß-sechs » Wed May 26, 2021 1:25 pm
Good luck :thumbs:
Wow! I feel for you bro....sounds EXACTLY like my experience (like, word for word :wink: )
I call plagiarism mikelien....FO :knob:
Steve2003rs6
Post by Steve2003rs6 » Wed May 26, 2021 1:43 pm
Just to confirm. Grizz at unit 20 informs me that they change the bufkin pipe without removing the engine.
Also called in at the machine Shop. The brass bufkin pipes x12 will be manufactured next week.
They have been waiting for the boss to go on holiday so that he doesn’t know anything about them.
Mɐʇʇ
Post by Mɐʇʇ » Wed May 26, 2021 2:58 pm
Somewhere, there's some instructions on how to do it engine in, I am sure I have read them. And then took the engine out anyway.. :audibash:
Riggs
Post by Riggs » Wed May 26, 2021 6:39 pm
I did mine with engine in, just make sure when you get to the hex bolts on the oil filter/cooler housing you’ve got a good quality Allen key socket because their usually very tight and you don’t want to round them off !!! If you do engine is coming out.
Riggs
Post by Riggs » Wed May 26, 2021 6:44 pm
Just found a couple of pics when we were doing the job
Mɐʇʇ
Post by Mɐʇʇ » Wed May 26, 2021 6:47 pm
I rounded a Torx bolt off earlier in the week. Fortunately access was good so drilled it a bit to clean it up and then sacrificed a hex bit to broach a new hex in to it. Got away with it - if that had failed it would have been major disassembly.
Riggs
Post by Riggs » Wed May 26, 2021 7:39 pm
I know that feeling hence why I have loads of thread repair tools and easy outs !!!
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 78 guests
