Wideband AFR air fuel gauge
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Jan 09, 2006 3:18 pm
Has anyone fitted a Wideband AFR air fuel gauge to an S4 or RS4?
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
clived
Post by clived » Tue Jan 10, 2006 1:12 am
Not a direct help, but I fitted the AEM unit to my TT - great bit of kit and very accurate...
B7 S4 Cab
B5 RS4: MRC custom remap, Milltek 100cpi cats and rear system, RS6 8-pots, H&R PCS coilovers, H&R ARBs, AWE DTS, Tanoga Shortshift, Dynaudio / Focal / Genesis / iPod audio: SOLD, and still missed. One day....
smurfbus
Post by smurfbus » Tue Jan 10, 2006 10:08 am
I dont have the gauge but I use a LM-1 AF logger. The boost gauge is the only one I wanted to install and I dont even have time to look at it when I go WOT on normal roads. I bet you'll have trouble trying to take a look at the AF gauge too.
Good thing about the LM-1 is that you can get an kit with which has lots of other data also. check innovative lm-1 from google. they have also an gauge kit which is a bit cheaper.
clived
Post by clived » Tue Jan 10, 2006 10:29 am
Given all the mods on the car (the TT that is - 2.1 conversion, injectors, air flow stuff, fueling) I thought it wasn't a bad idea to at least have some flashing lights that would go red if something bad was happening ;-) But I wanted it in real time - I didn't want to be able to review how lean we'd gone after the engine had gone bang!
B7 S4 Cab
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Jan 10, 2006 11:01 am
To true. But not that easy to fit to a V6 engine. 2 downpipies.
MING BLUE AUDI S4
Car is on Lock down
smurfbus
Post by smurfbus » Tue Jan 10, 2006 1:07 pm
clived wrote:Given all the mods on the car (the TT that is - 2.1 conversion, injectors, air flow stuff, fueling) I thought it wasn't a bad idea to at least have some flashing lights that would go red if something bad was happening ;-) But I wanted it in real time - I didn't want to be able to review how lean we'd gone after the engine had gone bang!
I still have some trust on motronic7 to cut boost or throttle or add fuel if things start to look too wild, which they have a couple of times ; )
But nothing wrong in having an extra red light to come up when passing a trigger value.
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Jan 10, 2006 1:15 pm
True but the motronic 7 management is only as good as the REMAP it is running. Widebang AFR won't lie. if the car is running lean at any rev you will know.
Before the engine blow's LOL
MING BLUE AUDI S4
Car is on Lock down
BRETTCOLLINS
Post by BRETTCOLLINS » Fri Jan 13, 2006 10:00 am
This is the wideband AFR gauge that I have ordered for my car.
http://www.turbobits.co.uk/acatalog/inn ... und%2ehtml
MING BLUE AUDI S4
Car is on Lock down
clived
Post by clived » Fri Jan 13, 2006 10:12 pm
Gotta say I think the AEM is more OEM looking with its red LED display....
B7 S4 Cab
BRETTCOLLINS
Post by BRETTCOLLINS » Sat Jan 14, 2006 12:03 am
have ordered the gauge with red led display, so should look the same as AEM unit.
MING BLUE AUDI S4
Car is on Lock down
clived
Post by clived » Sat Jan 14, 2006 11:29 am
Good point. How did you get round the two downpipe issue that ruled the AEM out in your mind?
And how will you live without a swinging LED gauge ;-)
B7 S4 Cab
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Jan 16, 2006 9:45 am
Have swinging LED AFR gauge on my Rover 220 Convertible Turbo, So won't miss out LOL. As for the 2 downpipes on the S4, taping in the exhaust where the system meets just before the first box.
MING BLUE AUDI S4
Car is on Lock down
smurfbus
Post by smurfbus » Wed Jan 18, 2006 10:06 am
I take it you dont run CATs then? otherwice it will show incorrect values, but its not too bad if you know it.
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Jan 18, 2006 10:24 am
No cat's on the car. Custom Exhaust from turbo's back with 3" downpipes.
MING BLUE AUDI S4
Car is on Lock down
Users browsing this forum: No registered users and 58 guests
