Front centre speak vibration.
Anyone else suffer(ed) with the front centre speaker, on the dash below windscreen distorting/vibration when music up loud?
Taken apart but not really studied properly yet... still vibrating when playing high volume music.
TIA
TIA
Re: Front centre speak vibration.
Yes...standard A6 build. It wasn’t sorted at the factory until sometime after 2015 facelift. Take it to dealer they’ll sort on warranty.
Or just disconnect it and enjoy the huge improvement in sound and stereo imagery.
Seriously?... or you pulling my leg?MikeFish wrote:Or just disconnect it and enjoy the huge improvement in sound and stereo imagery.
Serious. I couldn't stand how all the focus was in the centre and distracted from the stereo imagery. And it is an awful speaker. So I disconnected and it sounds so much better now. Not sure why they thought stereo music should be mainly coming from a centre channel!?! I understand if watching a DVD you'd want the focus to be the centre channel for dialogue but not when listening to music.
Update- I didn’t disconnect the speaker, but instead removed the cover/grill, then laid it back in place without pushing in to enable the clips.
It’s slightly raised now, so not as flush, but the vibration has gone without loosing a speaker.
Happy
Happy
Does anyone have any ideas on how to disconnect the speaker? Can we just pull a fuse, or do you need to take the unit out?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Cheers, I will give it a go, our of interest can you just remove the trim bit around it and pull it out?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
The trim is just held in with plastic clips. If you have any trim removal tools take the thinnest one and wedge it into the edge closest to you and lift the trim out. If you don't have trim removal tools then maybe something like a screwdriver with a rag over the end to protect the dash will do.
Once the trim is off, the speaker is held down with 2 screws (either tor or allen key, can't remember). As the isn't much height due to the windscreen I used a little socket set with the right bit to loosen it then just twisted the bit with my fingers to completely remove the screws. Probably takes longer to type this all up and read it then actually do it.
Cheers Mike - I'll give it a go tomorrow
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Trusty dinner knife worked for me, but don’t tell the wifey
Anyone replaced the speaker, any idea on size? Or Is the vibration the grill?
Users browsing this forum: No registered users and 69 guests
