Front centre speak vibration.
RSVI
Post by RSVI » Sun Jan 06, 2019 8:13 pm
Anyone else suffer(ed) with the front centre speaker, on the dash below windscreen distorting/vibration when music up loud?
Taken apart but not really studied properly yet... still vibrating when playing high volume music.
TIA
Image Image Image
doodlebug
Re: Front centre speak vibration.
Post by doodlebug » Sun Jan 06, 2019 8:25 pm
Yes...standard A6 build. It wasn’t sorted at the factory until sometime after 2015 facelift. Take it to dealer they’ll sort on warranty.
RSVI
Post by RSVI » Sun Jan 06, 2019 8:41 pm
Thanks Doodle
Image Image Image
Post by MikeFish » Sun Jan 06, 2019 9:04 pm
Or just disconnect it and enjoy the huge improvement in sound and stereo imagery.
RSVI
Post by RSVI » Sun Jan 06, 2019 10:51 pm
MikeFish wrote:Or just disconnect it and enjoy the huge improvement in sound and stereo imagery.
Seriously?... or you pulling my leg?
Image Image Image
Post by MikeFish » Sun Jan 06, 2019 11:33 pm
Serious. I couldn't stand how all the focus was in the centre and distracted from the stereo imagery. And it is an awful speaker. So I disconnected and it sounds so much better now. Not sure why they thought stereo music should be mainly coming from a centre channel!?! I understand if watching a DVD you'd want the focus to be the centre channel for dialogue but not when listening to music.
RSVI
Post by RSVI » Mon Jan 07, 2019 9:47 pm
Cheers, I’ll give it a go
Image Image Image
RSVI
Post by RSVI » Mon Feb 18, 2019 6:13 pm
Update- I didn’t disconnect the speaker, but instead removed the cover/grill, then laid it back in place without pushing in to enable the clips.
It’s slightly raised now, so not as flush, but the vibration has gone without loosing a speaker.
Happy
Image Image Image
dannyuk
Post by dannyuk » Thu Feb 21, 2019 3:56 pm
Does anyone have any ideas on how to disconnect the speaker? Can we just pull a fuse, or do you need to take the unit out?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Post by MikeFish » Thu Feb 21, 2019 6:18 pm
Speakers don't have fuses. Just unplug the speaker itself.
dannyuk
Post by dannyuk » Fri Feb 22, 2019 8:41 pm
Cheers, I will give it a go, our of interest can you just remove the trim bit around it and pull it out?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Post by MikeFish » Fri Feb 22, 2019 8:59 pm
The trim is just held in with plastic clips. If you have any trim removal tools take the thinnest one and wedge it into the edge closest to you and lift the trim out. If you don't have trim removal tools then maybe something like a screwdriver with a rag over the end to protect the dash will do.
Once the trim is off, the speaker is held down with 2 screws (either tor or allen key, can't remember). As the isn't much height due to the windscreen I used a little socket set with the right bit to loosen it then just twisted the bit with my fingers to completely remove the screws. Probably takes longer to type this all up and read it then actually do it.
dannyuk
Post by dannyuk » Fri Feb 22, 2019 11:28 pm
Cheers Mike - I'll give it a go tomorrow :)
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
RSVI
Post by RSVI » Mon Feb 25, 2019 12:42 pm
Trusty dinner knife worked for me, but don’t tell the wifey Image
Image Image Image
ab54666
Post by ab54666 » Thu Jun 27, 2019 9:33 am
Anyone replaced the speaker, any idea on size? Or Is the vibration the grill?
Users browsing this forum: No registered users and 22 guests
