ECS RACE N75 Valve
2.7 V6 30v biturbo - 380 bhp
JonnyX
Post by JonnyX » Thu Nov 24, 2005 12:26 am
If you run that valve you will get limp mode and throttle cut. It's a POS on the S4 so I would guess
the same on the RS4.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
dodgydave
Re: ECS RACE N75 Valve
Post by dodgydave » Mon Nov 28, 2005 2:43 pm
zeke wrote:Have anybody install this type of valve on the RS4?
This is the link http://www.ecstuning.com/stage/n75-info.html [img]images/graemlins/audiS4black.gif[/img]
Guys, you can just adjust the screw on the standard N75 to achieve the same !! I'm sure that's what they've done!
JonnyX
Post by JonnyX » Mon Nov 28, 2005 7:49 pm
No, it's not what they have done. The ECS Race valve is not adjustable. I
think it's the valve from the 2.2 5 cylinder turbo in RS2 guise. You can
adjust the stock valve but it's not recommended as it's pretty easy to
fubar. If you want more boost get a remap.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
dodgydave
Post by dodgydave » Mon Nov 28, 2005 7:56 pm
well, I've adjusted the screw. It's a bit of a twiddle but it works. But I've still got a brand new RS2 N75. I'll try that sometime and let you know how it went.
dodgydave
Post by dodgydave » Mon Nov 28, 2005 8:00 pm
JonnyX wrote:If you run that valve you will get limp mode and throttle cut. It's a POS on the S4 so I would guess
It won't work without a remap or clamping the MAP if you run standard software.
JonnyX
Post by JonnyX » Mon Nov 28, 2005 8:29 pm
I would say that if you are getting a remap then you don't need to change
the valve at all anyway. You just change the duty cycle which is part of the
map. As you say, you could clamp the MAP but thats a bit drastic for most
people and I am not sure what impact that would have on the rest of the
car
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Users browsing this forum: jdp and 80 guests
