RS6 C7 | 800+ BHP
Re: RS6 C7 | 800+ BHP
Post by MikeFish » Mon Jan 29, 2018 8:14 pm
You did mention it but it was later in the thread and I hadn't seen it until after I replied.
dasquade
Post by dasquade » Tue Jan 30, 2018 1:03 am
For what it is worth, somebody on audizine (made a simular topic over there some time ago), replied that it would be better to fully heatshield the manifolds. We have different manifolds (double shielded air gapped manifold compaired to cast one piece/pipes). Also since there isn't much room or airflow between the V, fully isolate should be better (and pray the construction is capable to widstand the trapped heat inside). I think it would be good to keep a good eye on the EGT (exhaust temps). Fact is, in my case, S6 C7 stage 2, i don't 'race' it long time and my daily trips are short....
*he has tuned S4
hulk_rs
Post by hulk_rs » Thu Feb 01, 2018 3:06 pm
hope this is possible as atm no uk tuner can offer 1000bhp on rs6/7 atm otherwise mine would be having it done
Post by MikeFish » Thu Feb 01, 2018 8:12 pm
DXB_RS6 wrote:
Mon Jan 29, 2018 5:19 pm
I'm booked in for the aquamist system installation on Thursday.
Emailed loads of turbos options. Let me know if you need some direction.
Sent from my SM-G955F using Tapatalk
So, it's Thursday! How did the install go?
DXB_RS6
Post by DXB_RS6 » Thu Feb 01, 2018 8:22 pm
Dropped it off this morning, they said it will take 2 working days. Hopefully get it back Saturday. Will take a log to assess if a new tune modification is required.
Will let you know when it's ready.
finance-nick
Post by finance-nick » Thu Feb 01, 2018 9:08 pm
Where is it being done ?
dasquade
Post by dasquade » Thu Feb 01, 2018 9:17 pm
I hope you asked for some pictures of the install :). Curious where they will install the nozzles and what types etc :).
But looking forwards to the results :).
finance-nick
Post by finance-nick » Thu Feb 01, 2018 9:35 pm
Where is it being fitted? What dealer
Post by MikeFish » Fri Feb 02, 2018 12:24 am
He lives in Dubai.
finance-nick
Post by finance-nick » Fri Feb 02, 2018 12:31 am
Yes, full IAT info, power increase info, and photo's would be absolutely fantastic !!!
DXB_RS6
Post by DXB_RS6 » Fri Feb 02, 2018 6:52 am
Here's some questions (and answers) I asked before installing..
Here are my questions:
1. What model of aquamist system will be installed on my car?
HFS4 ver 3.1 board
2. On what basis does the system discharge the spray? Turbo boost? Revs? Etc?
Fuel injector duty cycle (in your case the direct injectors) coupled with turbo boost pressure. The ratio of influence of either input is adjustable by a knob.
3. What size nozzle will be used?
Dual 1.2mm will be enough for 50-50 mix. If you're going with a 75-25 meth then you can go bigger but you need quad noozzles with the accompanying complications so we try to avoid 4 nozzles.
4. What warranty is given with the system?
Regular aquamist warranty as below:
Aquamist Warranty:
We will only honor a warranty claim under the following conditions:
A copy of invoice must be accompanied with a claim.
Serial number of the system should be submitted (full system)
Claim must be filed within 12 month of purchase, regardless of usage
Your first contact of a claim must be the original supplier.
Warranty is not transferable from the original owner.
Warranty does not cover physical damage, arose from incorrect wiring, faulty installation, frost damage, water ingression etc.
DXB_RS6
Post by DXB_RS6 » Fri Feb 02, 2018 6:57 am
On another note. I must have spoken to at least 5 different tuners from around the world and all of them seem to think the Forge Charge Cooler is a waste of money and won't do anything. Strange how each one said the same things.
Also, a local garage tried to sell me the REVO intake system. I wasn't really convinced but if I got it at a good price I would have probably taken it. Upon a side by side comparison of the intakes (stock and revo), I was shocked (and he was embarrassed) to see absolutely no difference between the 2 intakes. Both we're identical except one had a small revo badge on it.
They must use the stock intake and just put a badge on it. Complete waste of money and surprising!
DXB_RS6
Post by DXB_RS6 » Fri Feb 02, 2018 6:58 am
finance-nick wrote:Where is it being fitted? What dealer
It's a local instal in Abu Dhabi, UAE.
finance-nick
Post by finance-nick » Fri Feb 02, 2018 9:55 am
Exactly, the intakes are more mostly for show rather than performance. Looking forward to the results !!!
hulk_rs
Post by hulk_rs » Fri Feb 02, 2018 11:07 am
thats correct the forge cooler is a waste of time i know people who fitted it ended up going back to stock,only solution will be the mrc intercooler i think ,and agreed all the intakes have been no better than stock with a filter inside the forge intake loses 20 bhp over stock ,look forward to seeing the results for the meth and the gains /failsafes in place as meth has good gains but high rsk
