dasquade wrote: ↑Sat Jan 27, 2018 2:46 pmDecided to order 2 sheets Heatshield Armor Downpipe Shield Kit ½" x 10" x 36" (155.82£ shipped to Belgium).
In the first place to wrap the manifolds and hot side turbo's. Not sure if wrapping the cold side is a good thing (the aluminum might be better of unwrapped).
I'll see how far i get with those 2 sheets, maybe with the rest i should be able to cover half of my downpipes and the oil/coolant pipes of turbo's. Altough maybe again it is best not to cover the hot lines so heat isn't trapped, but cove the inlet lines and prevent them from heat).
Will see how it goes...
epic, well done take some before and after shots and heat measurements with a cheap laser heat gun, will be so interesting. no need to wrap the actual turbo, just the manifolds will create the seperation needed
when can we look forward to the results?
