naaaa
rs4 bns engine built
Re: rs4 bns engine built
See Now we talking! Wasn’t difficult was it to start a meaning full thread full of pictures and sexy ass details
. This looks epic! Wondering if magical 1000bhp is possible on this motor... keep it up.!
. This looks epic! Wondering if magical 1000bhp is possible on this motor... keep it up.! Sent from my iPhone using Tapatalk
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
- Bladerider
Fair enough,
Dont want to come across as a nob on a thread thats actually of something interesting, but theres something very off about those times in a car with 850bhp, those are comparable to trap speeds of 650bhp GTRs (old RB engined ones) with similar weight, grip and dynamics.
Interested to see more as you post.
Im guessing Pauter rods ??
- Surrey Sam
Nice seeing a built engine, you sticking with the wet sump?
m2motortechnik
- 1st Gear
skylline gtr weight 3300 lbs at most compere to our 4000 lbs rs4 thats 700 lbs less ,and you are talking 650 whp not bhp ,my car makes about 700 awhp right now so its only a 50 whp diferance give or takeBladerider wrote: ↑Wed Jan 10, 2018 12:58 amFair enough,
yes pauter custom made the rods to my specs and they are made in titanium
Last edited by m2motortechnik on Wed Jan 10, 2018 1:30 am, edited 1 time in total.
m2motortechnik
- 1st Gear
my turbos are capable to flow enought for 1200 whp,everything is already done on my car,fueling ect....all i need is to swap the built motor in and start tuning it for for more boost
but i want to settle for 1000 whp give or take ,that my goal
m2motortechnik
- 1st Gear
yes ,i already ran the stock engine till 9500 rpm a few times to check and loged my oil pressure and its all goodSurrey Sam wrote: ↑Wed Jan 10, 2018 1:03 amNice seeing a built engine, you sticking with the wet sump?
- Surrey Sam
Pressure should be fine, I'd have been tempted to Knife Edge the crank if sticking with the wet sump setup.m2motortechnik wrote: ↑Wed Jan 10, 2018 1:28 amyes ,i already ran the stock engine till 9500 rpm a few times to check and loged my oil pressure and its all goodSurrey Sam wrote: ↑Wed Jan 10, 2018 1:03 amNice seeing a built engine, you sticking with the wet sump?![]()
m2motortechnik
- 1st Gear
you dont need to there is baffle plate in thoes motor ,the crankshaft doesnt splash into oil,audi thought of everything on thoes motorsSurrey Sam wrote: ↑Wed Jan 10, 2018 1:33 amPressure should be fine, I'd have been tempted to Knife Edge the crank if sticking with the wet sump setup.m2motortechnik wrote: ↑Wed Jan 10, 2018 1:28 amyes ,i already ran the stock engine till 9500 rpm a few times to check and loged my oil pressure and its all goodSurrey Sam wrote: ↑Wed Jan 10, 2018 1:03 amNice seeing a built engine, you sticking with the wet sump?![]()
- Surrey Sam
A little knifing would also balance out the reciprocal mass from installing your other lightweight components. Small gains, but still. It looks pretty.
m2motortechnik
- 1st Gear
the crank assembly got fully balanced for the new weight of the rods and pistonsSurrey Sam wrote: ↑Wed Jan 10, 2018 1:51 amA little knifing would also balance out the reciprocal mass from installing your other lightweight components. Small gains, but still. It looks pretty.
dougle_turbo
Please can we have some video? I want to hear it!
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
dougle_turbo
p.s great work
2010 987 Cayman S.
This is pornographic, keep it coming
m2motortechnik
- 1st Gear
not much videos but here is two,this is still on stock motor and 13 psi
https://www.youtube.com/watch?v=H62h5RiKOyk
https://www.youtube.com/watch?v=9ICemy_VU8w
this was a test pass at 11 psi and lower timing
https://www.youtube.com/watch?v=R1k9wt-o_hY
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 242 guests
