Oil cooler DIY
Re: Oil cooler DIY
Might be a pain to sort now but i put back to back steel fittings on to the oil cooler with my own made pipes,
The reason i done this is so i will never have to undo the steel fitting from the aluminium cooler again, just undo the steel pipe fitting from the steel fitting so shouldn't corroded, if the makes any sence at all
Re: Oil cooler DIY
#2 for setrab oil coolers . Get steel fittings like mentioned above . Done it on my B5 RS4 . Same problems of corroded fittings/pipes . 1/3rd of price of oem . Ironic really as they are oem supplier of oil cooler on the B5 .
dougle_turbo
Re: Oil cooler DIY
As Cov says, it's a pretty straightforward job that shouldn't take long. In fact, taking the bumper on and off is the most difficult bit (especially if it's just you). Take some care when removing/refitting the hoses from the engine. The bolts didn't inspire me with much confidence, I think they would be very easy to overtighten and strip. Also, make sure you lightly lube up (ahemm) the seals before fitting the new hoses. If you pinch and damage the o-ring they cost something like £25 each!
A definite +1 on the wax oil, that should keep moisture out of the joint.
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
Re: Oil cooler DIY
Check, ill pick up a Durex 24 pack this evening.
Audi Pardner
Re: Oil cooler DIY
jonytek - I did a sort of pictorial type thread a couple of years back on here when I changed my cooler that might be some help. Can't find the link though, sorry. It'll be something like 'replacing the oil cooler' I expect
Re: Oil cooler DIY
Now need to dump the oil from the whole motor just collect what drains from the cooler. When you take the unions of the engine block you'll only get the tiniest amount come out. When refitted just run for 10-20 seconds at idle initially then refill what you lost from the cooler. No more than a couple of litres at a guess
repsol honda fireblade.
Re: Oil cooler DIY
All done. It was much easier than I thought. Whole job took around 3 hours. Still got the old cooler if anyone wants it, I haven't removed the pipes.
Re: Oil cooler DIY
I’d take the old one if possible, pm how much you want for itjonytek wrote:All done. It was much easier than I thought. Whole job took around 3 hours. Still got the old cooler if anyone wants it, I haven't removed the pipes.
Re: Oil cooler DIY
Well done jony
Re: Oil cooler DIY
Sorry mate someone took it off one of the FB pages, it wasn't you was it? I let it go for 75. It's not an easy thing to price when you dont know if its salvageable.
Re: Oil cooler DIY
No it wasn’t, no problem
Re: Oil cooler DIY
I have a forge cooler sitting in the house, i will be fitting when I get home from work mid January. So I might have the old one available.
Current Toys -
B7 Audi RS4 Avant - Phantom Black
E92 DCT M3 LE500 - Imola Red
Navara NP300 Tekna
E36 BMW M3 Evo track Car - Cosmos Black
Navara NP300 Tekna
Re: Oil cooler DIY
Price wise does that not work out about the same as a new forge or OEM cooler at £721? Where have you saved £1000?jonytek wrote: ↑Mon Dec 18, 2017 5:24 pmIve heard the same. No real benefit.
Ive just ordered a Radtec cooler £418 delivered Wednesday - https://www.ebay.co.uk/itm/Audi-RS4-B7- ... SwB-1Yr~3o
TPS can have the hoses for next day delivery so Ill go in on Wednesday ready to fit Thursday..
8E0 117 315 @£139 + vat
8E0 117 316 @£164 + vat
Just saved myself 1K, pretty happy with that..
Can't wait to do some donuts in the snow now...![]()
Only asking as mine m\needs done and I'd prefer to spend less if I can, although I have already purchased the forge cooler.
Cheers.
Current Toys -
Navara NP300 Tekna
Navara NP300 Tekna
Re: Oil cooler DIY
You'll need the lines also which were around 327 and then the labor quoted for fitting.RS4JAY wrote: ↑Sun Dec 31, 2017 8:48 amPrice wise does that not work out about the same as a new forge or OEM cooler at £721? Where have you saved £1000?jonytek wrote: ↑Mon Dec 18, 2017 5:24 pmIve heard the same. No real benefit.
Cheers.
Re: Oil cooler DIY
the forge comes with lines mate?jonytek wrote: ↑Sun Dec 31, 2017 11:16 amYou'll need the lines also which were around 327 and then the labor quoted for fitting.RS4JAY wrote: ↑Sun Dec 31, 2017 8:48 amPrice wise does that not work out about the same as a new forge or OEM cooler at £721? Where have you saved £1000?jonytek wrote: ↑Mon Dec 18, 2017 5:24 pmIve heard the same. No real benefit.
Cheers.
Current Toys -
Navara NP300 Tekna
Navara NP300 Tekna
Users browsing this forum: Google [Bot] and 337 guests
