Oil cooler DIY
Lukes3
Re: Oil cooler DIY
Post by Lukes3 » Tue Dec 19, 2017 10:38 am
Might be a pain to sort now but i put back to back steel fittings on to the oil cooler with my own made pipes,
The reason i done this is so i will never have to undo the steel fitting from the aluminium cooler again, just undo the steel pipe fitting from the steel fitting so shouldn't corroded, if the makes any sence at all
dhali
Re: Oil cooler DIY
Post by dhali » Tue Dec 19, 2017 10:53 am
#2 for setrab oil coolers . Get steel fittings like mentioned above . Done it on my B5 RS4 . Same problems of corroded fittings/pipes . 1/3rd of price of oem . Ironic really as they are oem supplier of oil cooler on the B5 .
dougle_turbo
Re: Oil cooler DIY
Post by dougle_turbo » Tue Dec 19, 2017 10:57 am
As Cov says, it's a pretty straightforward job that shouldn't take long. In fact, taking the bumper on and off is the most difficult bit (especially if it's just you). Take some care when removing/refitting the hoses from the engine. The bolts didn't inspire me with much confidence, I think they would be very easy to overtighten and strip. Also, make sure you lightly lube up (ahemm) the seals before fitting the new hoses. If you pinch and damage the o-ring they cost something like £25 each!
A definite +1 on the wax oil, that should keep moisture out of the joint.
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
jonytek
Re: Oil cooler DIY
Post by jonytek » Tue Dec 19, 2017 11:01 am
Covkiller wrote:
Tue Dec 19, 2017 10:13 am
Wear protection :jump_clap:
Check, ill pick up a Durex 24 pack this evening.
BUILD THREAD
IG: @bad_rs_4
Audi Pardner
Re: Oil cooler DIY
Post by Audi Pardner » Tue Dec 19, 2017 10:59 pm
jonytek - I did a sort of pictorial type thread a couple of years back on here when I changed my cooler that might be some help. Can't find the link though, sorry. It'll be something like 'replacing the oil cooler' I expect :D
rocket1
Re: Oil cooler DIY
Post by rocket1 » Thu Dec 21, 2017 12:07 am
Now need to dump the oil from the whole motor just collect what drains from the cooler. When you take the unions of the engine block you'll only get the tiniest amount come out. When refitted just run for 10-20 seconds at idle initially then refill what you lost from the cooler. No more than a couple of litres at a guess
repsol honda fireblade.
jonytek
Re: Oil cooler DIY
Post by jonytek » Thu Dec 21, 2017 6:29 pm
All done. It was much easier than I thought. Whole job took around 3 hours. Still got the old cooler if anyone wants it, I haven't removed the pipes.
BUILD THREAD
IG: @bad_rs_4
Rw@@dy
Re: Oil cooler DIY
Post by Rw@@dy » Thu Dec 21, 2017 7:46 pm
jonytek wrote:All done. It was much easier than I thought. Whole job took around 3 hours. Still got the old cooler if anyone wants it, I haven't removed the pipes.
I’d take the old one if possible, pm how much you want for it
Covkiller
Re: Oil cooler DIY
Post by Covkiller » Thu Dec 21, 2017 10:40 pm
Well done jony :thumbs:
jonytek
Re: Oil cooler DIY
Post by jonytek » Fri Dec 22, 2017 2:17 pm
Sorry mate someone took it off one of the FB pages, it wasn't you was it? I let it go for 75. It's not an easy thing to price when you dont know if its salvageable.
BUILD THREAD
IG: @bad_rs_4
Rw@@dy
Re: Oil cooler DIY
Post by Rw@@dy » Fri Dec 22, 2017 2:22 pm
No it wasn’t, no problem
RS4JAY
Re: Oil cooler DIY
Post by RS4JAY » Sun Dec 31, 2017 8:42 am
I have a forge cooler sitting in the house, i will be fitting when I get home from work mid January. So I might have the old one available.
Current Toys -
B7 Audi RS4 Avant - Phantom Black
E92 DCT M3 LE500 - Imola Red
Navara NP300 Tekna
E36 BMW M3 Evo track Car - Cosmos Black
RS4JAY
Re: Oil cooler DIY
Post by RS4JAY » Sun Dec 31, 2017 8:48 am
jonytek wrote:
Mon Dec 18, 2017 5:24 pm
Ive heard the same. No real benefit.
Ive just ordered a Radtec cooler £418 delivered Wednesday - https://www.ebay.co.uk/itm/Audi-RS4-B7- ... SwB-1Yr~3o
TPS can have the hoses for next day delivery so Ill go in on Wednesday ready to fit Thursday..
8E0 117 315 @£139 + vat
8E0 117 316 @£164 + vat
Just saved myself 1K, pretty happy with that..
Can't wait to do some donuts in the snow now... :jump_clap: :jump_clap:
Price wise does that not work out about the same as a new forge or OEM cooler at £721? Where have you saved £1000?
Only asking as mine m\needs done and I'd prefer to spend less if I can, although I have already purchased the forge cooler.
Cheers.
Current Toys -
Navara NP300 Tekna
jonytek
Re: Oil cooler DIY
Post by jonytek » Sun Dec 31, 2017 11:16 am
Cheers.
You'll need the lines also which were around 327 and then the labor quoted for fitting.
BUILD THREAD
IG: @bad_rs_4
RS4JAY
Re: Oil cooler DIY
Post by RS4JAY » Sun Dec 31, 2017 11:27 am
Cheers.
the forge comes with lines mate?
Current Toys -
Navara NP300 Tekna
Users browsing this forum: No registered users and 354 guests
