Adaptive Xenons ??
5.0 V10 50v biturbo - 571 bhp
HPsauce
Re: Adaptive Xenons ??
Post by HPsauce » Fri Nov 24, 2017 12:51 am
Golfather wrote:
Fri Nov 24, 2017 12:38 am
Adaptive headlamps are definately an option for C6's
Look for 8Q5 on the build Sticker in your boot or your service book:
PRCode: 8Q5 = Headlight-range adjustment automatic/ dynamic with dynamic bending light (AFS 1)
Well done that man! :thumbs:
HPsauce wrote:
Thu Nov 23, 2017 3:18 pm
Or check the build Sticker, someone may know the codes to look for.
We await your answer..... :wink:
Jess
Post by Jess » Fri Nov 24, 2017 11:06 am
I am not sure why are we thinking they are an option when the UK Audi brochure has them listed as standard spec...I am confused, but it doesn't take much these days tbh lol.
I did check the book, not "that Book" Golfather,...and yes it has that 8Q5 code listed. :)
HPsauce
Post by HPsauce » Fri Nov 24, 2017 11:19 am
So you need diagnostics run then, VCDS or dealer as noted above.
don0301
Post by don0301 » Fri Nov 24, 2017 11:19 am
Maybe standard on FL models but option on pre-FL? Mine's pre FL and has them
I'm sure I recall they start working above 20mph?
I can definitely tell mine are working when driving around non well lit areas (obvious to see), I wasn't aware mine had it until after I had bought and driven. The selling dealer didn't know..
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah :shock:
Jess
Post by Jess » Fri Nov 24, 2017 11:46 am
OK- You might be right then Don, yes the brochure is Oct 2009.
I think I expected too much from my Audi dealer, as they were unable to give me any convincing answers, and even tried telling me that I was getting confused with "cornering lights" which is something that I know is not there, as we have air intakes instead of separate front foglights.
Trups
Trader (Expired)
Post by Trups » Thu Nov 30, 2017 9:27 pm
All the C6 headlights I have worked on have them.
Tell tail sign that's fast, open bonnet, remove the cover from the front panel to the bumper (wont be any screws) and look at the side of the headlight, there will/should be a black box attached to the headlight.
As Ian says, its hard to notice them moving but when driving if you move to the right then only the right will move, when going left the left one moves, not as obvious on standard headlights as they are crap to say the least.
Henry3467
Post by Henry3467 » Fri Dec 01, 2017 2:29 am
It’s quite easy to see if the lights are adaptive if you take the cover off where the main h2s bulb is located there should be a motor on that unit looks like a screw thread if that’s there there adaptive you can actually set the headlights to turn with Ross tech which puts them on a showroom setting which allows the headlights to turn when stationary failing that I think it kicks in about 15 miles an hour
Your headlights may have been changed as replacements with the bi xenon are roughly a £1000 each if you can take a pic of the rear of the headlamp with the cover off Ie inside I’ll tell you straight away there’s also a couple of plastic swivel fittings that get brittle and snap which obvously render the bi xenon inoperable
Hope this helps cheers
Henry3467
Post by Henry3467 » Fri Dec 01, 2017 2:33 am
By the way all rs6 c6 were fitted with adaptive lights and the 10 bulb drl all other c6 models have the 6 bu-lbs drl with no eyebrow
Jess
Post by Jess » Fri Dec 01, 2017 8:46 am
I complained to Audi. It had the desired sobering effect for the main dealer. They have discovered a whole new bunch of diagnostics to be done, and confirmed adaptive lights fitted. They have booked the car in for a few days.
Service wise a lot has changed since that banking caused recession I feel. Corners being cut all over the place these days.
Jim Haseltine
Post by Jim Haseltine » Fri Dec 01, 2017 9:54 am
Yes, they're difficult to detect when driving - even when looking for the movement I only see it in a couple of places during my daily commute and then it's only a suggestion of movement rather than something obvious.
gorwanvfr
Post by gorwanvfr » Fri Dec 01, 2017 3:24 pm
If you get the Trups quad upgrade you can not miss the lights moving. In fact a few times I have caught myself looking at the movement of the light rather than looking at the road ahead. :bigblink:
RS6 C6 (Gone but not forgotten)
Golf R
Delorean DMC 12
Jaguar MK2
E-type
Jess
Post by Jess » Fri Dec 01, 2017 5:36 pm
It has Trups headlight upgrade from a previous owner on here, I am hoping that isn't the cause of the malfunction tbh. Both rear number plate lights also are a little temperamental, as is one of the overhead reading lights. All were replaced together. Could just be coincidence however.
Trups
Trader (Expired)
Post by Trups » Fri Dec 01, 2017 8:03 pm
if there was a fault with the adaptive system there would be an error.
Trups
Trader (Expired)
Post by Trups » Fri Dec 01, 2017 8:04 pm
Also which/whose car was it?
AL0500
Post by AL0500 » Wed Dec 06, 2017 12:15 pm
I think the queries have all been covered. I’ll add...
- the cornering sweep of the lights occurs at any speed above +10kph
- if this module fails the errror on the dash states ‘adaptive light defective’ or at least very similar wording.
Adam
RS6 Wagon - C6
