Exhaust flap continually open findings
dasquade
Re: Exhaust flap continually open findings
Post by dasquade » Sun Nov 13, 2016 10:50 pm
Hard crowd :)
*somehow it's a bug with dropbox (if you rightclick on the image and view it, it shows correct).
*yes, 'just' a S6 hence the gearshift i don't care about atm.
*nvm...
Tadass910
Post by Tadass910 » Mon Nov 14, 2016 12:07 pm
dasquade wrote:Still wondering if there is a code to manually code them out/in again :s.
*Why didn't it came with an exhaust button (like R8)
Still searching for a way to install my R8 GT steeringwheel in the 6 (some are working on it)
In my opinion it's weird to install r8 steering wheel into rs6, concerning exhaust button we can choose to make exhaust loader from comfort to dynamic so it no point for such button, if you want exhaust dynamic you go to to individual and make exhaust to dynamic and valves open
zeshark
Post by zeshark » Fri Jun 09, 2017 4:12 pm
MikeFish wrote:
Sun Nov 13, 2016 7:37 pm
However, it does flag an alarm. It doesn't show on the dash or MMI but if you plug a laptop in it will show the error. But if you are happy with the sound then you can buy the Milltek valve delete modules that cancel the error.
Anyone knows the actual PN of the Milltek valve delete module ? I searched through their site but can't find it listed.
Some resellers in the US carry it but its odd not to find it on their website.
2017 RS6 C7 Performance - 2008 997 GT3 - 2001 550 Maranello - 1998 355 GTS F1 - 2017 225xe
Iain
Post by Iain » Fri Jun 09, 2017 4:32 pm
Remember to cover up the plugs - I disconnected them, valves open; plugs corroded..... just cost me £360 to have them all put right again at the dealer. Chirping sound, I mentioned on another thread is down to almost nothing now and one appreciates the valves closed and the neighbour doesn't have to cover her ears in the morning
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
dasquade
Post by dasquade » Fri Jun 09, 2017 5:56 pm
For what it is worth, i installed CETE exhaust valve controle module recently and does the job perfectly :).
https://www.active-sound.eu/en/audi/aud ... ve-control
Active Valve Control
You drive an Audi S6 4G / RS6 4G and it’s equipped with an exhaust system including valve control at delivery?
You would like to control the valves individually?
It also bothers you to open the valves every time again if you start the engine?
With our Active Valve Control you can get complete control of the exhaust valves in your Audi S6 4G / RS6 4G.
Functions
The module can be installed fast and easy via Plug&Play and the original state of your car stays retained.
No external buttons are needed. The entire comfortable handling is controlled by already existing buttons/other controls inside the car.
Following functions are available with Audi Drive Select menu:
Audi Drive Select: Comfort Mode
Both exhaust valves are closed (even while cold start)
Audi Drive Select: Auto Mode
Possibility to go to original mode anytime
Audi Drive Select: Dynamic Modus
Both exhaust valves are open permanently
Innovative features
Protection of engine (security function)
Fully loaded car drives with closed exhaust valves can damage your engine. That’s why our module opens valves from revs of about 5,000 RPM in order to protect the engine.
Reversal of valves via original button
You’ll have the possibility to reverse the valves during dynamic as well as comfort mode. That means: You’re driving in comfort mode with closed valves but wish to open them? No problem, just click on the original button twice.
Post by MikeFish » Fri Jun 09, 2017 6:38 pm
Milltek Part Code: SSXAU405
http://www.venommotorsport.com/product/exhausts/EX1729/
zeshark
Post by zeshark » Sat Jun 10, 2017 7:08 am
Thanks for the PN.
I made a test yesterday evening by disconnecting the flaps and protecting the terminals with duct tape.
I would not say that the result is outrageous, but at least, the clumsy transitions at low and mid revs are gone and there is a hint of V8 burble all the time. Definitely the way to go for me.
I had driven a pre-FL car extensively and my recollection was that the RS6 C7 had more personnality in the sound department.
zeshark
Post by zeshark » Sat Jun 10, 2017 7:28 am
An additional question: does each part of the set include connection to the flap actuator body and to the cable, so that both terminals are neatly protected ?
It is hard to tell from the pictures where the shiny end is actually a cap.
Bit_evl
Post by Bit_evl » Sat Jun 10, 2017 8:50 am
I watched the local kwik-botch fit mine and it appears to handle the cables but does not cover the connectors on the back boxes. Duct-tape is still your friend. I just gave them £20 and they did it on the ramp and cable tied the protected ends out of the way as well.
Post by MikeFish » Sat Jun 10, 2017 10:31 am
Yes the modules only protect the wire which is the hard bit to replace. Exhaust can be replaced easily if it did fill with dirt.
Post by Ian_C » Sat Jun 10, 2017 11:03 am
Genius! So simple! The Milltek equivalent of a condom
RS6chris!
Post by RS6chris! » Sat Jun 10, 2017 5:34 pm
So
If valves are open all the time....does that mean you get pops all the time too.
Or still just in sport/dynamic mode?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Iain
Post by Iain » Sat Jun 10, 2017 5:36 pm
When mine were open permanently, it would not pop in D or using the paddles
S on the other hand....pops and bangs
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
Post by MikeFish » Sat Jun 10, 2017 11:01 pm
So
The valves just control volume not pops and bangs. Pops and bangs are controlled by the gearbox (and therefore the engine map) being in Sport mode.
Doesn't matter whether you are in comfort or dynamic, selecting S on the gearbox in either mode with make it pop and bangs, selecting Drive in either mode will stop the pops and bangs.
The big advantage for me with the valves disconnected is that I don't need to cycle round to dynamic each time I start the car as my valves will still be open.
Scotty C
Post by Scotty C » Sat Jun 10, 2017 11:01 pm
Unplugged mine tonight and same as Iain above... however when revving in neutral (not a regular occurrence), I could barely get it to pop and bang, whereas my Pre FL sounded aggressive. Not entirely sure if that has anything to do with disconnecting the plugs or maybe something else...
Current: 2019 BMW Alpina - B5 Bi Turbo Touring
Current: 2014 Land Rover Defender 110 All Black
Previous: 2017 RS6 Performance - Misano Red with Black Styling Pack
Previous: 2014 RS6 - Misano Red
Previous: 2004 S4 Avant - Nogaro Blue
Previous: 2001 S3 Absolute Red
Users browsing this forum: No registered users and 88 guests
