*somehow it's a bug with dropbox (if you rightclick on the image and view it, it shows correct).
*yes, 'just' a S6 hence the gearshift i don't care about atm.
*nvm...
In my opinion it's weird to install r8 steering wheel into rs6, concerning exhaust button we can choose to make exhaust loader from comfort to dynamic so it no point for such button, if you want exhaust dynamic you go to to individual and make exhaust to dynamic and valves opendasquade wrote:Still wondering if there is a code to manually code them out/in again :s.
*Why didn't it came with an exhaust button (like R8)
Still searching for a way to install my R8 GT steeringwheel in the 6 (some are working on it)
Anyone knows the actual PN of the Milltek valve delete module ? I searched through their site but can't find it listed.
Active Valve Control
You drive an Audi S6 4G / RS6 4G and it’s equipped with an exhaust system including valve control at delivery?
You would like to control the valves individually?
It also bothers you to open the valves every time again if you start the engine?
With our Active Valve Control you can get complete control of the exhaust valves in your Audi S6 4G / RS6 4G.
Functions
The module can be installed fast and easy via Plug&Play and the original state of your car stays retained.
No external buttons are needed. The entire comfortable handling is controlled by already existing buttons/other controls inside the car.
Following functions are available with Audi Drive Select menu:
Audi Drive Select: Comfort Mode
Both exhaust valves are closed (even while cold start)
Audi Drive Select: Auto Mode
Possibility to go to original mode anytime
Audi Drive Select: Dynamic Modus
Both exhaust valves are open permanently
Innovative features
Protection of engine (security function)
Fully loaded car drives with closed exhaust valves can damage your engine. That’s why our module opens valves from revs of about 5,000 RPM in order to protect the engine.
Reversal of valves via original button
You’ll have the possibility to reverse the valves during dynamic as well as comfort mode. That means: You’re driving in comfort mode with closed valves but wish to open them? No problem, just click on the original button twice.
The valves just control volume not pops and bangs. Pops and bangs are controlled by the gearbox (and therefore the engine map) being in Sport mode.
