4 spoke MFSW swap to 3 spoke paddle shift - what do I need?
Hi guys,
I have a 3 spoke paddle shift RS6 wheel I want to swap for my dated 4 spoke MFSW. I'm going to be getting it done but could do with your help.
Is it a big job?
What do I need?
Do I need to purchase anything else?
Any horn, fixing, wiring etc that I need to know about?
This is the wheel I am putting on -
http://s550.photobucket.com/user/witwer ... l.jpg.html
Help would be much appreciated:)
Warwick
Is it a big job?
What do I need?
Warwick
Re: 4 spoke MFSW swap to 3 spoke paddle shift - what do I need?
Just a Vagcom since you're going from hi-spec to base model spec.
Thanks. So will the paddles be fully functional too? No airbag issues or anything?
You will be able to code the slip ring for the paddles. Airbag is the same, IIRC. Should be fairly straightforward.
That's good to know. Thanks very much for the info buddy.
Didn't Amar do this? Thought he needed extra parts (more than just the steering wheel)?
Either way, I don't blame you for swapping it. I take it you'd had enough of bringing your food back up every time you sat in the car?
This is from Amars MFSW thread -
He mentioned a ew slip ring and connector plug. Grizz said there was only 1 slip ring on etka for both 3 spoke wheel and the poverty spec 4 spoke though. Don't know what the connector plug is?Mr V10 wrote: ↑Fri Mar 30, 2012 5:10 pmDunc, you can have the other 40k mile one, bloke is in Brum. I'll send you the details if you want. I also picked up a new steering wheel badge from Audi, it cost £30!! The parts guy couldn't believe it, they said it was £25 but then slapped VAT on there. I hate it when people quote plus VAT. Just waiting on my slip ring and a connector plug and I can get this bad boy on. Not had a lot of interest in the four spoke!![]()
Hmmm. There are a few different part numbers for the slip rings.
1J0 959 654 AL for the MFSW.
1J0 959 654 M for the 3 Spoke.
Maybe my recollection that the MSFW one can do both is false. You might need a 3 spoke slip ring.
I think all the information you need is here:
viewtopic.php?t=96142
and here:
viewtopic.php?t=67012
I think I was thinking of the control module relay which the 3 spoke doesn't use.
and here:
Hi guys,
Thanks for this. Seems like a massive headache!?
I don't know where to start really. I'm going on a a long trip in the car mid May time and I want to get this done but it's not looking good.
Where I can take it once I have the parts is another matter.
There is a slip ring (used) on eBay from a parts seller in Germany for £115. What do you reckon?
Forgive me, I'm hopeless from a mechanical standpoint
And yes Chunky, id had enough of throwing up all over the dash haha
If you're going from the 4 spoke to the 3 spoke you'll have to give up wearing tartan slippers and pipe smoking.
Visit these guys http://hazzydayz.com/
Errrm, take it to these guys. Hazydayz.
So 4 spoke does not have paddle shift ? Did I see that correctly ? Only base model has paddles ?
Users browsing this forum: Google Adsense [Bot] and 82 guests
