If I am not wrong matrix lights only started from 2015 models, 2014 and older are only with ledics3s wrote:Not a problem for me. I only have one child. And in rare cases there are 4 people in the car. Is it worth? I see that is has the audi plus inspection and that color tho.
Forgot to ask one thing at the start of the topic:
Matrix headlights, are they good? Do they come in the dynamic pack?
Tips on buying an used RS6 C7
Re: Tips on buying an used RS6 C7
Does anyone know if i buy the from Audi or Audi partners that has the Audi used car plus (Audi gebrauchtwagen plus) will i get warranty? Or can i extend it? Will i be able to use it in other EU country at Audi dealers?
RS6 C7 '14
Honda S2000 '03
Infiniti FX 35 '08 (US model)
Lexus IS '06 220d (sold)
Peugeot 206 '01 2.0 Hdi (sold)
VW Touareg 2.5 R5 TDI '03 (sold)
Alfa Romeo 156 2.0 T Spark '99 (first car) (sold)
Honda S2000 '03
That's a question for your dealer, terms will be dictated in country.
Best if you buy directly from Audi centerics3s wrote:Does anyone know if i buy the from Audi or Audi partners that has the Audi used car plus (Audi gebrauchtwagen plus) will i get warranty? Or can i extend it? Will i be able to use it in other EU country at Audi dealers?
Is it safe to use the Launch Control on the pre-FL?
RS6 C7 '14
Honda S2000 '03
Honda S2000 '03
There isn't one, apart from traction control off, hold brake and accelerator & go. I've only done it twice, it gets of the line very quickly without it.ics3s wrote:Is it safe to use the Launch Control on the pre-FL?
So just brute force it? Does the revs go to red limiter or does the car hold it to the optimal RPM?zzz wrote:There isn't one, apart from traction control off, hold brake and accelerator & go. I've only done it twice, it gets of the line very quickly without it.ics3s wrote:Is it safe to use the Launch Control on the pre-FL?
Sorry guys if i bug you with all these questions. This will be my first Audi and i'm the type of guy that wants to know everything about the car.
RS6 C7 '14
Honda S2000 '03
Honda S2000 '03
You're holding the car on the brake. Going to the red line isn't likely to do good things to the torque converter if you can hold it.
On the pre-FL is the 75 litter fuel tank standard? Because i found a mentioning about it in an optional package "Convenience package"
RS6 C7 '14
Honda S2000 '03
Honda S2000 '03
With ESP off/ and oil temp above 70c, dropped down into S, you put your left foot firmly on the brake and right foot flat to the floor.ics3s wrote:So just brute force it? Does the revs go to red limiter or does the car hold it to the optimal RPM?zzz wrote:There isn't one, apart from traction control off, hold brake and accelerator & go. I've only done it twice, it gets of the line very quickly without it.ics3s wrote:Is it safe to use the Launch Control on the pre-FL?
The revs will only rise to approximately 2800rpm and stay there. As you are holding it on the brake, you want to let go pretty quickly as you are loading up the transmission. Works well in a standard car. Very difficult to do in a tuned car as the brakes just cant hold the increased torque.
MY16 Audi RS6
Can a dealer plug the key in to one of their magical machines and check to see the number of times the car's been launched? I know BMW can do this?
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
As there's no launch programme I would assume not.
Good point.doodlebug wrote:As there's no launch programme I would assume not.
The car is also so fast vs everything else on the road that 'launch' is utter overkill. I've done it once just to try the theory.
Current Fleet:
2016 Audi RS6 Performance
2015 Porsche 991 GT3
2015 Porsche 991 Carrera 4 Cab
2012 Porsche Cayenne Diesel
2010 Land Rover Defender 5.0 V8
I looked on VCDS and couldn't find a counter on either the RS6 or RS3 (which has proper launch control) but the RS4 B8 does have a counter.longman h wrote:Can a dealer plug the key in to one of their magical machines and check to see the number of times the car's been launched? I know BMW can do this?
Users browsing this forum: Bing [Bot] and 56 guests
