Cheers Coffeycoffey555 wrote:1-5-4-8-6-3-7-2
Carbon clean with DIY walnut shell blaster
Re: Carbon clean with DIY walnut shell blaster
- TonyHayers
- 5th Gear
Has it completely given up the ghost or is it just the thermal cutout. Mine kept going every 15 mins or so, but leave it 20 mins and would be back again.bazza138 wrote:Long time away from doing this , but 1/2 off work to try this![]()
But started doing this bloody Hoover has given up !!! Ffs Now off to buy cheap Hoover
06 Phantom Black Saloon:
^ GONE
^ GONE
pixsaudisex2
Well i must say done this last weekend wow what a difference, Really shocked how much better it feels..
On an awesome write up.
Just thermal cut out keeps going ! Every 5mins grrrrr , only done 4 ports !! 4 to go !!
Also blown oil cooler hose has gone ! I got warranty cover on it , maybe a claim on the oil cooler and hoses
ring them up today and see what what's !
Right I'm 6/8 done !
Is the normal bit of oil here !! In the manifold Is it the oil / cooling system breather separator faulty ???
bazza138 wrote:Right I'm 6/8 done !
Cheers Rick
- TonyHayers
- 5th Gear
Just back from hols. Yeah, the layer of oil in manifold is to be expected.
^ GONE
^ GONE
Now clean and rebuild her !!
Finally de coked done ! Spark plugs changed!
Now about to change oil hoses ! And oil & filter
Question
Esp light on dash !!
Dose this need to re set , or will this go out on when on 1st drive ?
S Button exhaust flaps not opening ! I see what happens when I take girl out Tomoz !
Question
It should go out after a little while of driving.
Or you have a vak leak on her. Look under the front carbon fiber cover where they join up you have put the pipe back on?
All the pipes vacuum are on ! I re located the vacuum check value to under the small carbon cover ! I tackle that job soon
Oil hose off !! What a bag ball of a job that was !! Threads all gone on the oil cooler !!
So new cooler to buy now !!
first time I did it i left of one of the manifold flap position sensors. That lit up my EML. I'd lay money on a vac line or an unplugged flap sensor. I've had the manifold off 4 times in total and only had the light on the once.
