Carbon clean with DIY walnut shell blaster
bazza138
Re: Carbon clean with DIY walnut shell blaster
Post by bazza138 » Sat Jun 06, 2015 5:12 pm
coffey555 wrote:1-5-4-8-6-3-7-2
Cheers Coffey :) only managed to get 4,8 done yesterday !! Nxt Friday the other 6 :)
TonyHayers
Post by TonyHayers » Sat Jun 06, 2015 10:06 pm
bazza138 wrote:Long time away from doing this , but 1/2 off work to try this :)
But started doing this bloody Hoover has given up !!! Ffs
Now off to buy cheap Hoover
Has it completely given up the ghost or is it just the thermal cutout. Mine kept going every 15 mins or so, but leave it 20 mins and would be back again.
06 Phantom Black Saloon:
^ GONE :cry:
pixsaudisex2
Post by pixsaudisex2 » Wed Jun 17, 2015 9:47 pm
Well i must say done this last weekend wow what a difference, Really shocked how much better it feels.. :) :jump_clap: :jump_clap: :jump_clap: :jump_clap:
On an awesome write up.
bazza138
Post by bazza138 » Thu Jun 18, 2015 10:21 am
Just thermal cut out keeps going ! Every 5mins grrrrr , only done 4 ports !! 4 to go !!
Also blown oil cooler hose has gone ! I got warranty cover on it , maybe a claim on the oil cooler and hoses :) ring them up today and see what what's !
bazza138
Post by bazza138 » Tue Jun 23, 2015 6:10 pm
Right I'm 6/8 done !
Is the normal bit of oil here !! In the manifold Is it the oil / cooling system breather separator faulty ???
bazza138
Post by bazza138 » Tue Jun 23, 2015 6:11 pm
bazza138 wrote:Right I'm 6/8 done !
Rick_RS4
Post by Rick_RS4 » Tue Jun 23, 2015 10:19 pm
common
bazza138
Post by bazza138 » Tue Jun 23, 2015 10:22 pm
Cheers Rick
TonyHayers
Post by TonyHayers » Fri Jun 26, 2015 12:45 pm
Just back from hols. Yeah, the layer of oil in manifold is to be expected.
^ GONE :cry:
bazza138
Post by bazza138 » Fri Jun 26, 2015 3:09 pm
Now clean and rebuild her !! :)
bazza138
Post by bazza138 » Sat Jul 04, 2015 6:54 pm
Finally de coked done ! Spark plugs changed!
Now about to change oil hoses ! And oil & filter
Question
Esp light on dash !!
Dose this need to re set , or will this go out on when on 1st drive ?
S Button exhaust flaps not opening ! I see what happens when I take girl out Tomoz !
docurley
Post by docurley » Sat Jul 04, 2015 8:48 pm
It should go out after a little while of driving.
Lukes3
Post by Lukes3 » Sat Jul 04, 2015 10:11 pm
Or you have a vak leak on her. Look under the front carbon fiber cover where they join up you have put the pipe back on?
bazza138
Post by bazza138 » Sat Jul 04, 2015 10:26 pm
All the pipes vacuum are on ! I re located the vacuum check value to under the small carbon cover ! I tackle that job soon
Oil hose off !! What a bag ball of a job that was !! Threads all gone on the oil cooler !!
So new cooler to buy now !!
RS6BRIT
Post by RS6BRIT » Sun Jul 05, 2015 10:22 am
first time I did it i left of one of the manifold flap position sensors. That lit up my EML. I'd lay money on a vac line or an unplugged flap sensor. I've had the manifold off 4 times in total and only had the light on the once.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 123 guests
