Rear seats creek & squeek
2.7 V6 30v biturbo - 380 bhp
Golich
Post by Golich » Mon Mar 21, 2005 1:28 pm
It sounds identical to my problem with the pin that locks the seat upright. Greasing it didn't really work. Did you find any residue of paint or shiney parts indicating rubbing parts i.e. worn paint, metal, plastic etc? If you fold the seat back up but don't engage it in the locking pin what does it still squeek?
JohnBlade
Post by JohnBlade » Thu Apr 07, 2005 2:20 pm
Silence at last ! Creamed up all the seats and greased the pins and surprise,surprise no more squeeks.The leather cream took a couple of days to settle but it seems to have done the trick.Thanks for all the advise.
DaveP
Post by DaveP » Thu Apr 07, 2005 2:45 pm
JohnBlade wrote:Silence at last ! Creamed up all the seats...
:shock:
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
Golich
Post by Golich » Thu Apr 07, 2005 7:07 pm
:jump:
bobjebb
Post by bobjebb » Thu Apr 07, 2005 7:57 pm
Hmm sounds like we now know what caused the squeek in the first place....
Disgusting.
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Morpheous
Post by Morpheous » Thu Apr 07, 2005 9:50 pm
I used some flocked double sided tape on the luggage cover mounting points and Krytox rubber seal lube on all the door rubbers. No noises at all now.
Noise from door seals chaffing used to drive me nuts.
simple1
Post by simple1 » Thu Apr 07, 2005 9:53 pm
Anything chaffing usually has that effect on your nuts :biggrin3: :assflash:
JohnBlade
Post by JohnBlade » Fri Apr 08, 2005 10:20 am
Any ideas for squeaking driver's seat ?? No 'pervy' comments please.... :lol:
Brooner
Post by Brooner » Fri Apr 08, 2005 10:38 am
Just the same as rear seats give them a dame good seeing to :shock: with your leather cream and grease on the mounts
JohnR
Post by JohnR » Fri Apr 08, 2005 11:02 am
More cream......will give it a go.But be 'springs' or similar
Golich
Post by Golich » Fri Apr 08, 2005 12:45 pm
Morpheous wrote:I used some flocked double sided tape on the luggage cover mounting points and Krytox rubber seal lube on all the door rubbers. No noises at all now.
Top tips Morpheous. I too have a prob with what I think is the door seals as I had the door taken to bits to investigate to no avail. I wondered if it was the rubbers. Where can I get Krytox rubber seal lube or equivalent? Does it leave a sticky residue?
simple1
Post by simple1 » Fri Apr 08, 2005 1:06 pm
Drivers seat can be more of an issue, I had three seat bases changed before I got one that wouldnt protest at having a FB sat on it :lol:
Golich
Post by Golich » Tue Apr 12, 2005 6:14 pm
simple1 wrote:Drivers seat can be more of an issue, I had three seat bases changed before I got one that wouldnt protest at having a FB sat on it :lol:
Yeah this has been a prob with a lot of the S4s too, and not just the Recorro spec'd cars. You can generall tell its coming from the front seats and not the rears tho.
