c6 wheels
iR8V10
RE: Re: RE: c6 wheels
Post by iR8V10 » Tue Jun 15, 2010 6:05 pm
Looks great, what spacers or nuts did you use?
Drc suspension or coilies?
iR8V10
Re: RE: Re: RE: c6 wheels
Post by iR8V10 » Tue Jun 15, 2010 6:08 pm
Ceveman73 wrote:Does anyone know if a wider tyre will fit on these wheels under the C5 arches without rubbing? The 9.5 inch +30 offset MTM wheels for the C5 run up to 275 width tyres with no probs. I was hoping to run 275 tyres on the C6 RS6 wheels. Can ppl confirm that the C6 Rs6 wheels run a +35 offset?
Any thoughts?
Mart.
I thought the same but they are et 36 with a 20 inch, the MTMs are 19's.
Ceveman73
Post by Ceveman73 » Wed Jun 16, 2010 9:52 am
paulm846 wrote:Image
By paulm846 at 2010-06-15
Not sure what you mean? The actual wheel diameter doesn't make a difference as long as the overall wheel + tyre diameter doesn't differ from the standard setup by much.
We know for a fact that 275/30/19 tyres fit without rubbing on MTM 19x9.5 +30 wheels.
So this means that a 275/25/20 tyre on the +36 offset 20x9.5 C6 wheels will fit with a 6mm spacer as the offset will be the same, and overall diamter is almost identical. Right?
C.
RS6Steve
RE: Re: RE: Re: RE: c6 wheels
Post by RS6Steve » Sun Aug 01, 2010 8:31 pm
Daniel,
Can you confirm the exact colour of you car?
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
iR8V10
Post by iR8V10 » Sun Aug 01, 2010 8:37 pm
Sprint Blue isn't it?
RS6Steve
Post by RS6Steve » Sun Aug 01, 2010 8:38 pm
Not convinced, looks a bit darker. No?
Steve
iR8V10
Post by iR8V10 » Sun Aug 01, 2010 8:40 pm
Prolly just the light..
grizz
Post by grizz » Sun Aug 01, 2010 8:45 pm
Here's mine ..
Unit 20
0151 3366888
iR8V10
Post by iR8V10 » Sun Aug 01, 2010 8:50 pm
and mine...not put on this thread yet!
Ceveman73
Post by Ceveman73 » Mon Aug 02, 2010 11:20 pm
What size spacers are you guys running?
M.
C6 RS6 Plus with a few sensible mods...
grizz
Post by grizz » Tue Aug 03, 2010 6:41 am
A small spacer on the front due to the 390mm discs .. No rear spacer ..
Unit 20
0151 3366888
iR8V10
Post by iR8V10 » Tue Aug 03, 2010 8:56 am
3mm shims so wheel still sits on the hub. Going to get the front brake caliper support trimmed so I can run without spacers soon.
Spacecowboy
Post by Spacecowboy » Wed Aug 04, 2010 1:05 am
more pics from this rs6 ?
Best Regards
Daniel
rs4 v8 - h&r - 20"wheels - slow but looks awesome
http://www.rs-quattro.de
