c6 wheels
RE: Re: RE: c6 wheels
Looks great, what spacers or nuts did you use?
Drc suspension or coilies?
Re: RE: Re: RE: c6 wheels
I thought the same but they are et 36 with a 20 inch, the MTMs are 19's.Ceveman73 wrote:Does anyone know if a wider tyre will fit on these wheels under the C5 arches without rubbing? The 9.5 inch +30 offset MTM wheels for the C5 run up to 275 width tyres with no probs. I was hoping to run 275 tyres on the C6 RS6 wheels. Can ppl confirm that the C6 Rs6 wheels run a +35 offset?
Any thoughts?
Mart.
Not sure what you mean? The actual wheel diameter doesn't make a difference as long as the overall wheel + tyre diameter doesn't differ from the standard setup by much.
We know for a fact that 275/30/19 tyres fit without rubbing on MTM 19x9.5 +30 wheels.
So this means that a 275/25/20 tyre on the +36 offset 20x9.5 C6 wheels will fit with a 6mm spacer as the offset will be the same, and overall diamter is almost identical. Right?
C.
RE: Re: RE: Re: RE: c6 wheels
Daniel,
Can you confirm the exact colour of you car?
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks
. Maybe RS5 or S5 Hatchback to come...
Sprint Blue isn't it?
Not convinced, looks a bit darker. No?
Steve
Prolly just the light..
Here's mine ..
Unit 20
0151 3366888
0151 3366888
and mine...not put on this thread yet!
A small spacer on the front due to the 390mm discs .. No rear spacer ..
Unit 20
0151 3366888
0151 3366888
3mm shims so wheel still sits on the hub. Going to get the front brake caliper support trimmed so I can run without spacers soon.
- Spacecowboy
Users browsing this forum: Majestic-12 [Bot] and 123 guests
