led side lights
led side lights
Can the side lights be replaced with white LED ones or do the they need to be a normal 501 bulb to not bring up a bulb fault on the DIS?
Re: led side lights
You can change them for led ones with no problems, fairly cheap on Ebay..johnny11 wrote:Can the side lights be replaced with white LED ones or do the they need to be a normal 501 bulb to not bring up a bulb fault on the DIS?
RE: Re: led side lights
I saw white side lights on a C5 on Sunday and then compared them to standard ones which were very yellow.
The white ones really suited it more. I`ve enquired about a set on ebay but the seller has got back to me saying the ones he sells does bring up faults on the DIS.
Re: RE: Re: led side lights
The ones I've got in mine are from Ebay and have never shown any faults.johnny11 wrote:I saw white side lights on a C5 on Sunday and then compared them to standard ones which were very yellow.
The white ones really suited it more. I`ve enquired about a set ebay but the seller has got back to me saying the ones he sells does bring up faults on the DIS.
Pete.
RE: Re: RE: Re: led side lights
These are the ones I fitted about a month ago..... http://www.ultraleds.co.uk/ultimate-501 ... -1684.html
Dearer than some I've seen on ebay but no fault codes/problems and so much better than the original ones.
Dave - are these ultraleds ones just a straight swap with the stock bulb?
Is it possible to change the main head lights for LED or is that too complicated??
Re: RE: Re: RE: Re: led side lights
When you say these are the ones 'you' fitted, thats not quite true is it? You couldn't work out how to open the bonnet could you?!RS6Dave wrote:These are the ones I fitted about a month ago..... http://www.ultraleds.co.uk/ultimate-501 ... -1684.html
hey chrisjohnny11 wrote:I saw white side lights on a C5 on Sunday and then compared them to standard ones which were very yellow.
am sure i got mine from ultraled's , go on , you know they look good on mine
has anyone replaced all the bulbs? i..e front side, rear tail, brake, reverse, fog, number plate. etc etc etc? is it better to replace the whole rear unit with an LED version or just replace the individual bulbs.
Phil i must admit they did look good on yours, and i`m on the web at the mo just dunno which ones to order, but if the majority is with the ultraleds it must be done.
you know it makes sense !!!
ordered, we see when thay arrive
I also have the Ultra Led's
look very good, very very bright.
Hehe. That'll be me. Next to Phil's, mine looked like candles! Or a torch with a normal bulb and half-used batteries.johnny11 wrote:I saw white side lights on a C5 on Sunday and then compared them to standard ones which were very yellow.
I never realised how yellow they were until we did a side-by-side comparison.
I must order some of these LED jobbies myself.
Hi Paul, just seen your reply! Yeah, just a straight swop. Don't know why you'd want to change your mains for LED though?? Surely the Xenons are bright enough!paul_23 wrote:Dave - are these ultraleds ones just a straight swap with the stock bulb?
Users browsing this forum: Google [Bot] and 94 guests
