led side lights
johnny11
led side lights
Post by johnny11 » Tue Feb 09, 2010 10:00 pm
Can the side lights be replaced with white LED ones or do the they need to be a normal 501 bulb to not bring up a bulb fault on the DIS?
pete2144
Re: led side lights
Post by pete2144 » Tue Feb 09, 2010 10:09 pm
johnny11 wrote:Can the side lights be replaced with white LED ones or do the they need to be a normal 501 bulb to not bring up a bulb fault on the DIS?
You can change them for led ones with no problems, fairly cheap on Ebay..
johnny11
RE: Re: led side lights
Post by johnny11 » Tue Feb 09, 2010 10:23 pm
I saw white side lights on a C5 on Sunday and then compared them to standard ones which were very yellow.
The white ones really suited it more. I`ve enquired about a set on ebay but the seller has got back to me saying the ones he sells does bring up faults on the DIS.
pete2144
Re: RE: Re: led side lights
Post by pete2144 » Tue Feb 09, 2010 10:30 pm
johnny11 wrote:I saw white side lights on a C5 on Sunday and then compared them to standard ones which were very yellow.
The white ones really suited it more. I`ve enquired about a set ebay but the seller has got back to me saying the ones he sells does bring up faults on the DIS.
The ones I've got in mine are from Ebay and have never shown any faults.
Pete.
RS6Dave
RE: Re: RE: Re: led side lights
Post by RS6Dave » Wed Feb 10, 2010 12:08 am
These are the ones I fitted about a month ago..... http://www.ultraleds.co.uk/ultimate-501 ... -1684.html
Dearer than some I've seen on ebay but no fault codes/problems and so much better than the original ones.
paul_23
Post by paul_23 » Wed Feb 10, 2010 6:29 am
Dave - are these ultraleds ones just a straight swap with the stock bulb?
Is it possible to change the main head lights for LED or is that too complicated??
ianS4
Re: RE: Re: RE: Re: led side lights
Post by ianS4 » Thu Feb 11, 2010 11:02 pm
RS6Dave wrote:These are the ones I fitted about a month ago..... http://www.ultraleds.co.uk/ultimate-501 ... -1684.html
When you say these are the ones 'you' fitted, thats not quite true is it? You couldn't work out how to open the bonnet could you?!
:assflash:
philroach
Post by philroach » Thu Feb 11, 2010 11:12 pm
hey chris
am sure i got mine from ultraled's , go on , you know they look good on mine :rocker:
jd_hants
Post by jd_hants » Fri Feb 12, 2010 10:55 am
has anyone replaced all the bulbs? i..e front side, rear tail, brake, reverse, fog, number plate. etc etc etc? is it better to replace the whole rear unit with an LED version or just replace the individual bulbs.
johnny11
Post by johnny11 » Fri Feb 12, 2010 5:09 pm
Phil i must admit they did look good on yours, and i`m on the web at the mo just dunno which ones to order, but if the majority is with the ultraleds it must be done.
philroach
Post by philroach » Fri Feb 12, 2010 5:19 pm
you know it makes sense !!!
johnny11
Post by johnny11 » Fri Feb 12, 2010 5:49 pm
ordered, we see when thay arrive
RS4XS
Post by RS4XS » Sun Feb 14, 2010 2:07 pm
I also have the Ultra Led's
look very good, very very bright.
MoRS6+
Post by MoRS6+ » Sun Feb 14, 2010 2:19 pm
Hehe. That'll be me. Next to Phil's, mine looked like candles! Or a torch with a normal bulb and half-used batteries.
I never realised how yellow they were until we did a side-by-side comparison.
I must order some of these LED jobbies myself.
RS6Dave
Post by RS6Dave » Sun Feb 14, 2010 3:34 pm
paul_23 wrote:Dave - are these ultraleds ones just a straight swap with the stock bulb?
Hi Paul, just seen your reply! Yeah, just a straight swop. Don't know why you'd want to change your mains for LED though?? Surely the Xenons are bright enough!
