led drl's
Brooner
Post by Brooner » Sat Nov 21, 2009 10:53 am
PG its easy raly just locate the 2 wieres and pull this will pull the bulb and holder out just a case of fiddling about till you get the right wires and just a push fit in the drivers side is a bit more of a pain than the passengers but took about 20 min form start to finish that included removing and fitting the trim and air duct
P_G
Post by P_G » Sat Nov 21, 2009 12:19 pm
Ta, I'll give it a go but the prospect of pulling wires.... :shock:
P_G
Post by P_G » Sat Nov 21, 2009 2:15 pm
Has anyone else tried this as I have pulled on the wires as hard as I dare and the nearside is just not coming out of its socket. Going to have to find someone with long fingers to have a go.
Brooner
Post by Brooner » Sat Nov 21, 2009 2:44 pm
Just make sure you pull straight on to the bulb and not at an angle i know i was reluctunt to pull hard but when straight on came out with out too much force
byron1313
Post by byron1313 » Sat Nov 21, 2009 6:37 pm
Just done mine, sidelights and DRL both the mirror white type bulbs from PRI - Drivers side a bitch as said before but took my time and walk away when you get frustrated, all goes back together OK and looks lots better. Slight blue tinge to the DRL bulb visible when off but not blue in use.
This helped loads. http://www.tyresmoke.net/forum/audi-rs/ ... -drls.html
P_G
Post by P_G » Sat Nov 21, 2009 8:06 pm
byron, did you do the same as Brooner when taking out the side light bulbs, just a strong tug on the leads?
byron1313
Post by byron1313 » Sun Nov 22, 2009 6:27 pm
Yup - on the passenger side you can actually feel the plastic holder and get a grip on the plastic holder that houses the bulb. Firm steady pull and it comes out easily. Getting back in is also easy.
On the drivers side the radiator hose makes access difficult but still OK either with the right hand (fingers) locate the brown and blue wires that go up into the top of the housing (there are 3 wires but the second brown not so obvious) and go as far along as you can and pull steadily. Also if you feel better use a pair of long nosed pliers with a angled head (B&Q) you can then get a good grip and just be brave and pull!!! Getting back in is OK as well just have to be patient and will all be OK. Worth it in the end I think. Good luck.
P_G
Post by P_G » Sun Nov 22, 2009 8:15 pm
Patience is a virtue and all that, managed to do it on the third time of trying. I think it was because I wasn't pulling them out straight by leaning over the front of the car / grille, leaning over the wings and accessing the bulbs that way proved much easier.
Agreed they are far better looking, again not LED bul better bu white light is an obvious improvement. Someone did ask at the petrol station today how my DRL's were white whereas their Mk VI golf DRL are yellow so let him into the secret.
Brooner
Post by Brooner » Mon Nov 23, 2009 6:28 pm
Hurra well done that man
scaghead
Post by scaghead » Mon Nov 23, 2009 9:57 pm
just ordered mine from pri racing and looking forward to mullering up my hands in changing them. will let you know how i got on.... cheers fellas for all the info
RS6chris!
Post by RS6chris! » Tue Nov 24, 2009 4:34 pm
Will someone please post the link to the exact LED bulbs i require for my DRLS?
The ones that just fit straight in without butchering wires etc.,,
This thread has lost me!!!! lol,
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
P_G
Post by P_G » Tue Nov 24, 2009 4:58 pm
byron1313
Post by byron1313 » Tue Nov 24, 2009 5:01 pm
byron1313
Post by byron1313 » Tue Nov 24, 2009 5:05 pm
Or if you are feeling really fancy these work apparently with no bulb out on the dash!! Just plugs in to the orig connector.
Sidelights though!
http://www.priracing.com/product.php/22 ... ars--pair-
jaseRS4
Post by jaseRS4 » Tue Nov 24, 2009 6:17 pm
DRL bulbs
http://www.priracing.com/product.php/26 ... a2ee724b27
Sidelights
http://www.priracing.com/product.php/13 ... ulb--pair-
PLEASE For clarification, if I buy the sidelight bulbs as listed above then I'll get a blown bulb message displayed on the dash ?
