led drl's
PG its easy raly just locate the 2 wieres and pull this will pull the bulb and holder out just a case of fiddling about till you get the right wires and just a push fit in the drivers side is a bit more of a pain than the passengers but took about 20 min form start to finish that included removing and fitting the trim and air duct
Just make sure you pull straight on to the bulb and not at an angle i know i was reluctunt to pull hard but when straight on came out with out too much force
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Just done mine, sidelights and DRL both the mirror white type bulbs from PRI - Drivers side a bitch as said before but took my time and walk away when you get frustrated, all goes back together OK and looks lots better. Slight blue tinge to the DRL bulb visible when off but not blue in use.
This helped loads. http://www.tyresmoke.net/forum/audi-rs/ ... -drls.html
Yup - on the passenger side you can actually feel the plastic holder and get a grip on the plastic holder that houses the bulb. Firm steady pull and it comes out easily. Getting back in is also easy.
On the drivers side the radiator hose makes access difficult but still OK either with the right hand (fingers) locate the brown and blue wires that go up into the top of the housing (there are 3 wires but the second brown not so obvious) and go as far along as you can and pull steadily. Also if you feel better use a pair of long nosed pliers with a angled head (B&Q) you can then get a good grip and just be brave and pull!!! Getting back in is OK as well just have to be patient and will all be OK. Worth it in the end I think. Good luck.
Patience is a virtue and all that, managed to do it on the third time of trying. I think it was because I wasn't pulling them out straight by leaning over the front of the car / grille, leaning over the wings and accessing the bulbs that way proved much easier.
Agreed they are far better looking, again not LED bul better bu white light is an obvious improvement. Someone did ask at the petrol station today how my DRL's were white whereas their Mk VI golf DRL are yellow so let him into the secret.
just ordered mine from pri racing and looking forward to mullering up my hands in changing them. will let you know how i got on.... cheers fellas for all the info
Will someone please post the link to the exact LED bulbs i require for my DRLS?
The ones that just fit straight in without butchering wires etc.,,
This thread has lost me!!!! lol,
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
DRL bulbs
http://www.priracing.com/product.php/26 ... t-rs4-drl-
Sidelights
http://www.priracing.com/product.php/13 ... ulb--pair-
Snap !!!
Sidelights
Snap !!!
Or if you are feeling really fancy these work apparently with no bulb out on the dash!! Just plugs in to the orig connector.
Sidelights though!
http://www.priracing.com/product.php/22 ... ars--pair-
Sidelights though!
DRL bulbs
http://www.priracing.com/product.php/26 ... a2ee724b27
Sidelights
PLEASE For clarification, if I buy the sidelight bulbs as listed above then I'll get a blown bulb message displayed on the dash ?
Sidelights
Users browsing this forum: No registered users and 188 guests
