Engine Rattle
slimmyreed
Engine Rattle
Hi Guys,
My car seems to have recently developed an engine rattle when starting from cold. It is only for a second after starting, but it isn't somthing i have noticed before.
It reminds me of the noise a car that has been sat for a long time makes when it is started, as there is not a drop of oil in the head.
Anyone elses car rattle on a cold start?
I also just had my cambelt changed at MRC, possibly related?
I have done a search of the forum, and i have seen that this has been talked about before, but not for a while, and with no definitive answer. Any developments on this subject?
Simon
P.S. My oil level is fine (first thing i checked)
Simon
MartWilliams
RE: Engine Rattle
hydraulic lifters being noisy while the oil pressure builds up? If it's that then it is probably normal
RE: Engine Rattle
sounds normal to me , especially now it is colder . Should only last a second or two until oil recirculates
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
RE: Engine Rattle
Hi there - all normal - postings will resume when the cold weather gets here!!
Dave
Dave
Hi, the rattle you hear is the camshaft timing chain tensioners. With age the oil seals perish in the tensioners causing oil holding pressure to drop overnight, as the engine is started it takes a moment for oil pressure to build up in the tensioners to tension the timing chain correctly, causing the chain to rattle. Simples
What timing chain?
the ones at the back of the engine?
Nice green 52 plate RS6
1974 Triumph Stag
1994 Landrover 110 CSW
Volvo V70
Pro photographer, weddings, parties, cars, track days, portraits or anything photograhic catered for, event Photography a specialty.
www.medwaystudio.co.uk
paul@medwaystudio.co.uk
1974 Triumph Stag
Volvo V70
Timing chain? I thought it was belt!
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
275 Vreds.
Miltek Resonated.
Hi Flow filters.
oil preesure
Correction , its a known fault by audi,theres a pressure relief valve in between the banks, this fails allowing all pressure to be released overnight,bitch to change ive lived with mine since purchase , still offputting.
RE: oil preesure
if it's any consolation, M5 V8 engines I've heard starting up from cold sound a lot worse than mine ...
RE: oil preesure
Yep, you are right they have chains just under the rocker covers.
If the tensioners go weak the chain will catch on the rocker cover itself.
Users browsing this forum: Bing [Bot] and 190 guests
