Engine Rattle
slimmyreed
Engine Rattle
Post by slimmyreed » Thu Oct 22, 2009 11:41 pm
Hi Guys,
My car seems to have recently developed an engine rattle when starting from cold. It is only for a second after starting, but it isn't somthing i have noticed before.
It reminds me of the noise a car that has been sat for a long time makes when it is started, as there is not a drop of oil in the head.
Anyone elses car rattle on a cold start?
I also just had my cambelt changed at MRC, possibly related?
I have done a search of the forum, and i have seen that this has been talked about before, but not for a while, and with no definitive answer. Any developments on this subject?
Simon
P.S. My oil level is fine (first thing i checked)
MartWilliams
RE: Engine Rattle
Post by MartWilliams » Fri Oct 23, 2009 12:34 am
hydraulic lifters being noisy while the oil pressure builds up? If it's that then it is probably normal
philroach
RE: Engine Rattle
Post by philroach » Fri Oct 23, 2009 7:54 am
sounds normal to me , especially now it is colder . Should only last a second or two until oil recirculates
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Daveperc
RE: Engine Rattle
Post by Daveperc » Fri Oct 23, 2009 9:15 am
Hi there - all normal - postings will resume when the cold weather gets here!!
Dave
slimmyreed
Post by slimmyreed » Fri Oct 23, 2009 8:43 pm
cool! :thumb:
mtech114
Post by mtech114 » Fri Oct 23, 2009 10:57 pm
Hi, the rattle you hear is the camshaft timing chain tensioners. With age the oil seals perish in the tensioners causing oil holding pressure to drop overnight, as the engine is started it takes a moment for oil pressure to build up in the tensioners to tension the timing chain correctly, causing the chain to rattle. Simples
Post by Shoppinit » Sat Oct 24, 2009 8:36 pm
What timing chain?
raceman
Post by raceman » Sat Oct 24, 2009 9:26 pm
the ones at the back of the engine?
Nice green 52 plate RS6
1974 Triumph Stag
1994 Landrover 110 CSW
Volvo V70
Pro photographer, weddings, parties, cars, track days, portraits or anything photograhic catered for, event Photography a specialty.
www.medwaystudio.co.uk
paul@medwaystudio.co.uk
ecain63
Post by ecain63 » Sat Oct 24, 2009 10:13 pm
Timing chain? I thought it was belt!
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
pete2144
Post by pete2144 » Sat Oct 24, 2009 10:49 pm
ecain63 wrote:Timing chain? I thought it was belt!
There are chains inside the rocker covers to keep the cams in time....
gorwanvfr
Post by gorwanvfr » Sun Oct 25, 2009 7:54 pm
Chains
kbee
oil preesure
Post by kbee » Mon Oct 26, 2009 12:37 pm
Correction , its a known fault by audi,theres a pressure relief valve in between the banks, this fails allowing all pressure to be released overnight,bitch to change ive lived with mine since purchase , still offputting.
Balchy
RE: oil preesure
Post by Balchy » Mon Oct 26, 2009 1:28 pm
if it's any consolation, M5 V8 engines I've heard starting up from cold sound a lot worse than mine ...
TIMSRS
RE: oil preesure
Post by TIMSRS » Fri Oct 30, 2009 10:03 pm
Yep, you are right they have chains just under the rocker covers.
If the tensioners go weak the chain will catch on the rocker cover itself.
Users browsing this forum: No registered users and 210 guests
