wobbly suspension?
wobbly suspension?
Guys,
For a while I've noted that at fairly high speed, a little flicker of the wheel and the back end is all over the place...I replaced the suspension to H&R coilover and currently have it pretty low down. I still have the overall soft and wallowy feeling, which I'd really like to tighten up, but at the same time I don't want my back to break on a long trip.
Any suggestions on what I can do to tighten things up a little? Do I have to go down the ARB's route or can new suspension bushes do the trick?
Thanks,
Stan
Thanks,
Stan
RE: wobbly suspension?
have you got uprated anti-roll bars ?,if not they will transform the car
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
- mikeyquattro
- Top Gear
replace all of the bushes. Even if you get new OEM bushes and not poly bushes, you will notice a massive difference
Tomorrow is another day
neckarsulm
Mikey, can you specify which particular ones need replacing?replace all of the bushes
- mikeyquattro
- Top Gear
the inner lower rear and front lower bushes take a lot of grief, but if you want to do the job properly change all of them
neckarsulm
Re: RE: wobbly suspension?
how many is that in total mike? how much would this cost to do any ideas?mikeyquattro wrote:the inner lower rear and front lower bushes take a lot of grief, but if you want to do the job properly change all of them
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
- mikeyquattro
- Top Gear
No!
Lots of grovelling under ramps to do rears. I done them in situ to save me from disconnecting the handbrakes and brake lines. I had an air chisel to colllapse the old metallastic bushes. Took me about 3 hours to do rear inner lower bushes
I replaced mine with powerflex too(much easier to install, but noisey!)
- mikeyquattro
- Top Gear
iirc 20 bushes front and back.rtd wrote:how many is that in total mike? how much would this cost to do any ideas?mikeyquattro wrote:the inner lower rear and front lower bushes take a lot of grief, but if you want to do the job properly change all of them
Approx £300-£350 for powerflex bushes plus labour if you don't diy
