wobbly suspension?
2.7 V6 30v biturbo - 380 bhp
RS4Ralph
wobbly suspension?
Post by RS4Ralph » Sun Jun 14, 2009 9:42 pm
Guys,
For a while I've noted that at fairly high speed, a little flicker of the wheel and the back end is all over the place...I replaced the suspension to H&R coilover and currently have it pretty low down. I still have the overall soft and wallowy feeling, which I'd really like to tighten up, but at the same time I don't want my back to break on a long trip.
Any suggestions on what I can do to tighten things up a little? Do I have to go down the ARB's route or can new suspension bushes do the trick?
Thanks,
Stan
imolas4uk
RE: wobbly suspension?
Post by imolas4uk » Mon Jun 15, 2009 12:34 am
have you got uprated anti-roll bars ?,if not they will transform the car
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
mikeyquattro
Post by mikeyquattro » Mon Jun 15, 2009 8:27 am
replace all of the bushes. Even if you get new OEM bushes and not poly bushes, you will notice a massive difference
Tomorrow is another day
neckarsulm
Post by neckarsulm » Tue Jun 16, 2009 3:49 pm
Mikey, can you specify which particular ones need replacing?
mikeyquattro
Post by mikeyquattro » Tue Jun 16, 2009 4:27 pm
the inner lower rear and front lower bushes take a lot of grief, but if you want to do the job properly change all of them
neckarsulm
Post by neckarsulm » Tue Jun 16, 2009 7:24 pm
easy DIY?
rtd
Re: RE: wobbly suspension?
Post by rtd » Tue Jun 16, 2009 7:26 pm
mikeyquattro wrote:the inner lower rear and front lower bushes take a lot of grief, but if you want to do the job properly change all of them
how many is that in total mike? how much would this cost to do any ideas?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
mikeyquattro
Post by mikeyquattro » Tue Jun 16, 2009 7:29 pm
No!
Lots of grovelling under ramps to do rears. I done them in situ to save me from disconnecting the handbrakes and brake lines. I had an air chisel to colllapse the old metallastic bushes. Took me about 3 hours to do rear inner lower bushes
I replaced mine with powerflex too(much easier to install, but noisey!)
mikeyquattro
Post by mikeyquattro » Tue Jun 16, 2009 7:32 pm
iirc 20 bushes front and back.
Approx £300-£350 for powerflex bushes plus labour if you don't diy
