no water to rear wiper
2.7 V6 30v biturbo - 380 bhp
GregorFuk
Post by GregorFuk » Mon Jan 19, 2009 5:33 pm
eh?
mylife98
Post by mylife98 » Tue Jan 20, 2009 12:46 am
GregorFuk wrote:Okay so I've fixed the problem. If anybody can recommend a good picture hosting site I'll post some picks and write a short description.
Flickr (http://www.flickr.com) is pretty good for free photo hosting although you'll probably have to hyperlink to thier pages.
Else if you want to compress and send the photos to me I can just put them up on my webspace and you can link to them directly.
PM me if you want to.
M
Audi B5 RS4 Standard. Avus Silver. Debadged. Supaglass.
reserves
Post by reserves » Tue Jan 20, 2009 10:25 am
Would appreciate some pics, mine's not working at the mo.
GregorFuk
Post by GregorFuk » Tue Jan 20, 2009 11:42 pm
Okay A few pics for you and a short description.
Step one.
Remove the kick panel at the side of the passengers foot well, an easy job as it's just two philips self tappers holding it on.
Step two.
Once the panel is removed you'll see a mass of wires but pull them aside and in the corner you should find the black ribbed hose that feeds the rear wiper. The hose comes in sections and as you can see from the picture there is a join in the foot well. Obviously with the cold weather my rear washer has frozen up, by actuating the pump the pressure has built up and popped the two sections apart.
Step three.
I popped the two sections back together then to make sure they'd stay connected in future I used three zip-ties to pull the two sections together, a rough but 'hopefully' permanent fix.
Step four.
Keep the screen wash/ anti freeze concentration high in the washer bottle. Resist the temptation to use the rear wash wipe in sub zero temps.
Hope this helps
Gregor
Remove the kick panel (two philips screws) to reveal a mass of wires.
The separated sections, tucked away at the back
Pulling the two sections together with zip ties, hopefully will stop them popping apart again.
GregorFuk
Post by GregorFuk » Tue Jan 20, 2009 11:43 pm
Bugger, photos have gone up in reverse, I'm sure you get the idea though.
Ransom
Post by Ransom » Wed Jan 21, 2009 8:16 am
Thanks very much GregorFuK, I'll have a look this weekend
Audi RS4 B5 in black - Stayed standard for a total of 4 weeks
Honda CBR1000RR Fireblade
KTM LC4 640 Supermoto
mylife98
Post by mylife98 » Thu Jan 22, 2009 12:59 am
Good writeup Gregorfuk, thanks!
Dont' worry about the photos - I got two photo links wrong in my first write-up on how to replace an alarm bonnet catch so they don't work at all!
We can figure it out from yours.
Cheers!
Ransom
Post by Ransom » Mon Jan 26, 2009 5:31 pm
Just had the kick panel off and couldn't find the mentioned pipe or any dampness. Where else could I look?
reserves
Post by reserves » Mon Jan 26, 2009 5:37 pm
I've read that there's another join in the engine compartment, press your rear wiper and see if any water drops out under the engine.
Ransom
Post by Ransom » Mon Jan 26, 2009 6:06 pm
I did check under the engine after using the wipers but doesn't seem to be leaking there either
hogansghost
Post by hogansghost » Tue Jan 27, 2009 5:40 pm
Well it's been a busy mouse.
I found this thread and had noticed my rear wash wipe stopped a week or 2 ago. Sure enough, water is leaking but it's dripping from the rear wheel arch. Seems to be running around the inside of the wheel arch and dripping where the arch meets the bumper.
I've had the wheel off but can't get access to the pipes and no joy on the interior so far either.
Any ideas are gratefully received !!
Daytona Grey RS6 & Black Optics
