newbi full of questions
2.7 V6 30v biturbo - 380 bhp
sfrs4
Post by sfrs4 » Mon Sep 29, 2008 6:25 pm
hi, just bought an rs4 b5 on a 2000 x reg and as this is my first vag i need a little help please.
1. the tick over sometimes miss's a little and so i thought i would use a vag com to find the problem, but i have been told that the vag com won't work on my car is this true?
2. when i change gear(any gear) i get a slight thump from the back of the car (like the rear diff is moving) any common fault i should look for?
3. when does this big grin go away?
done the jap thing, trying the euro thing!
davs4
RE: newbi full of questions
Post by davs4 » Mon Sep 29, 2008 6:44 pm
Welcome to the fold mate.
1.Vagcom will work chose the correct type though.
2.The clunk as such can be cured by fitting a DTS(do a serach on this)
3.The smile gets bigger when you mod :D
bastos
Post by bastos » Mon Sep 29, 2008 6:55 pm
we all have the clunk!!! its the b5's factory fault... i hate it.. :audibash:
volts
dont be hating.....
Contigo
Post by Contigo » Mon Sep 29, 2008 6:56 pm
Where are you based? I have VAG com and can make some readings for you if you need.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Mon Sep 29, 2008 7:17 pm
Hi saf, good to see you on here finally! r33 v-spec on the GTR board
VAG-COM should work, maybe to do with the lead.
As people have said clunk is quite normal, and you soon adapt to it, and make it less!
Virdee Autos ~ 07950-526592
Jarv
Post by Jarv » Mon Sep 29, 2008 7:20 pm
Mine misses on idle, I asked Doug about it last time I was at MRC and apparently they all do it, so I shouldn't worry about any of the issues you have at the mo. Be good to get it scanned for DTC's just in case though.
Mike
Q7
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Mon Sep 29, 2008 7:52 pm
Mine also does ever so slightly, if you are really anal about it!
sfrs4
Post by sfrs4 » Mon Sep 29, 2008 8:56 pm
now thats obvious as an ex skyline owner you start to listen to every bump grate and grind, and worry!
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Mon Sep 29, 2008 9:10 pm
Hahaha!
These are strong, very strong when looked after properly
ollys
Post by ollys » Tue Sep 30, 2008 9:39 am
Jarv wrote:Mine misses on idle, I asked Doug about it last time I was at MRC and apparently they all do it,
By 'misses' you mean misfires slightly? Mine does this on idle, I get the occasional shiver felt through the car and the idle slightly wobbles between 750 and 800 rpm. Had new plugs at MRC in July but does not seem to have cured it. Are you sure it's nothing to worry about - I keep reading on here about worn camshafts and misfires being a sign of this???
Olly
TopBear
Post by TopBear » Tue Sep 30, 2008 11:11 am
As long as its a genuine VAG-COM USB cable, it can be used on the B5
You can log realtime misfires on idle, by opening blocks 15 (Cylinders 1-3) + 16 (Cylinders 4-6) in VAG-COM's "Measuring Blocks".
Mines does sporadically also, and I've done loads of maintenance to the engine.
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
mikeyquattro
Post by mikeyquattro » Tue Sep 30, 2008 11:35 am
My idle is smoother with V power, than it is with Tesco 99
Tomorrow is another day
mbelle
Post by mbelle » Tue Sep 30, 2008 11:38 am
mikeyquattro wrote:My idle is smoother with V power, than it is with Tesco 99
Rubbish!
You must be using Tesco 97... :wink:
Marcus
Current: A C6 Audi
Previous: A B5 Audi
mikeyquattro
Post by mikeyquattro » Tue Sep 30, 2008 11:40 am
Rubbish!
I also found the idle on my camper was smoother on V power
mbelle
Post by mbelle » Tue Sep 30, 2008 12:42 pm
mikeyquattro wrote:
Rubbish!
I'm not convinced the V-Power up here is up to scratch, but I may try a tank in the near future and see if I notice any idling differences then.
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Users browsing this forum: Google [Bot] and 93 guests
