newbi full of questions
hi, just bought an rs4 b5 on a 2000 x reg and as this is my first vag i need a little help please.
1. the tick over sometimes miss's a little and so i thought i would use a vag com to find the problem, but i have been told that the vag com won't work on my car is this true?
2. when i change gear(any gear) i get a slight thump from the back of the car (like the rear diff is moving) any common fault i should look for?
3. when does this big grin go away?
done the jap thing, trying the euro thing!
RE: newbi full of questions
Welcome to the fold mate.
1.Vagcom will work chose the correct type though.
2.The clunk as such can be cured by fitting a DTS(do a serach on this)
3.The smile gets bigger when you mod
we all have the clunk!!! its the b5's factory fault... i hate it..
volts
dont be hating.....
dont be hating.....
Where are you based? I have VAG com and can make some readings for you if you need.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
2006 BMW M6 - GONE
- Virdee Autos
- Trader (Expired)
Hi saf, good to see you on here finally! r33 v-spec on the GTR board
VAG-COM should work, maybe to do with the lead.
As people have said clunk is quite normal, and you soon adapt to it, and make it less!
Virdee Autos ~ 07950-526592
- Virdee Autos
- Trader (Expired)
Mine also does ever so slightly, if you are really anal about it!
- Virdee Autos
- Trader (Expired)
Hahaha!
These are strong, very strong when looked after properly
By 'misses' you mean misfires slightly? Mine does this on idle, I get the occasional shiver felt through the car and the idle slightly wobbles between 750 and 800 rpm. Had new plugs at MRC in July but does not seem to have cured it. Are you sure it's nothing to worry about - I keep reading on here about worn camshafts and misfires being a sign of this???Jarv wrote:Mine misses on idle, I asked Doug about it last time I was at MRC and apparently they all do it,
Olly
As long as its a genuine VAG-COM USB cable, it can be used on the B5
You can log realtime misfires on idle, by opening blocks 15 (Cylinders 1-3) + 16 (Cylinders 4-6) in VAG-COM's "Measuring Blocks".
Mines does sporadically also, and I've done loads of maintenance to the engine.
- mikeyquattro
- Top Gear
- mikeyquattro
- Top Gear
I'm not convinced the V-Power up here is up to scratch, but I may try a tank in the near future and see if I notice any idling differences then.mikeyquattro wrote:I also found the idle on my camper was smoother on V powermbelle wrote:Rubbish!mikeyquattro wrote:My idle is smoother with V power, than it is with Tesco 99
You must be using Tesco 97...
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Current: A C6 Audi
Previous: A B5 Audi
