mrc 400 how much?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
wombar
RE: mrc 400 how much?
Post by wombar » Tue Sep 25, 2007 8:30 pm
Yep, good to know what kind of outlay one would be looking at should the turbo fairy pay a visit :)
saf
Post by saf » Tue Sep 25, 2007 8:37 pm
The turbo , clutch and egt fairy have all coming knocking on my door at the same time.
wombar
Post by wombar » Wed Sep 26, 2007 3:40 am
That's gotta suck :(
jeffw
Post by jeffw » Wed Sep 26, 2007 6:25 am
You would change the clutch when the engine is out anyway and the EGTs are relatively inexpensive so it's probable not much worse than the Turbos going on their own.
saf
Re: RE: mrc 400 how much?
Post by saf » Wed Sep 26, 2007 1:47 pm
jeffw wrote:You would change the clutch when the engine is out anyway and the EGTs are relatively inexpensive so it's probable not much worse than the Turbos going on their own.
Yes very true. But it still sucks, as I cant drive the car.
The EGT's sill working but Intermittant. The turbo's working but screaming like a banshee for the last 8000 miles so they gonna pop soon. The clutch just decided to start slipping about 6 weeks ago. 2 weeks ago decided it needed to be parked up.
So main issues is the clutch. In a way its a lucky escape. I was goign to do the EGT (Dreaded passenger side one), and drive the car for a bit. Because clutch is gone, Ill have to get the whole lot done at once. Far easier.
Doug_S2
Trader (Expired)
RE: Re: RE: mrc 400 how much?
Post by Doug_S2 » Sat Sep 29, 2007 2:43 pm
The minimum you need to do to get 400bhp is:
ko4 turbos
ko4 lower turbo inlet pipes
gut precats
catback exhaust
injectors
remap
rs4 clutch
You will get 400 on stock intercoolers and stock fuel pump - although as said, you are getting close to the limits of them.
a stock s4 clutch will not last long with 400bhp.
http://www.MRCtuning.com
GrimReaper
Post by GrimReaper » Sat Sep 29, 2007 5:32 pm
Mine should set me back £3k by the time i'm done which covers KO4's, RS4 intake pipes, RS4 clutch, injectors, fuel pump, RS4 IC's, custom MRC map. Exhaust already been sorted although doing bigger down pipes. All work apart from the map i'm doing myself (including pulling the engine) so save a fair bit of labour charge which i just couldn't afford on top of the upgrades.
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
Mikse
Post by Mikse » Wed Apr 30, 2008 11:58 am
Little OT but can and/or will MRC make a custom remap by just sending the ECU and a list of mods made in the car?
2001 S4 Avant
Blue_Thunder
Post by Blue_Thunder » Wed Apr 30, 2008 12:30 pm
Exceptionally OT.
Why don't you email them and ask?
Mikse
Post by Mikse » Wed Apr 30, 2008 3:20 pm
Well I actually have emailed to them but haven´t got no reply what so ever. So I thouhgt I´d ask here if anyone have done that.
2001 S4 Avant
kn9
Post by kn9 » Thu Aug 07, 2008 1:42 pm
I've just emailed them as well, to ask for a quote on a MRC 500 kit.
Hope they check their emails...
CliveH
Post by CliveH » Thu Aug 07, 2008 1:45 pm
Of course they do. What email address are you using?
kn9
Post by kn9 » Thu Aug 07, 2008 4:48 pm
they replied on the same day!!! thanks all
CliveH
Post by CliveH » Thu Aug 07, 2008 7:04 pm
:shock:
Clive
MilkybarKid
Post by MilkybarKid » Mon Sep 08, 2008 8:17 pm
Id guess price depends on anything else that needs fixed especially after the turbo fairys visited.
Im going 500ish, but with a lot of extra work done so thats irrelevant.
