mrc 400 how much?
RE: mrc 400 how much?
Yep, good to know what kind of outlay one would be looking at should the turbo fairy pay a visit
The turbo , clutch and egt fairy have all coming knocking on my door at the same time.
That's gotta suck
You would change the clutch when the engine is out anyway and the EGTs are relatively inexpensive so it's probable not much worse than the Turbos going on their own.
Re: RE: mrc 400 how much?
Yes very true. But it still sucks, as I cant drive the car.jeffw wrote:You would change the clutch when the engine is out anyway and the EGTs are relatively inexpensive so it's probable not much worse than the Turbos going on their own.
The EGT's sill working but Intermittant. The turbo's working but screaming like a banshee for the last 8000 miles so they gonna pop soon. The clutch just decided to start slipping about 6 weeks ago. 2 weeks ago decided it needed to be parked up.
So main issues is the clutch. In a way its a lucky escape. I was goign to do the EGT (Dreaded passenger side one), and drive the car for a bit. Because clutch is gone, Ill have to get the whole lot done at once. Far easier.
RE: Re: RE: mrc 400 how much?
The minimum you need to do to get 400bhp is:
ko4 turbos
ko4 lower turbo inlet pipes
gut precats
catback exhaust
injectors
remap
rs4 clutch
You will get 400 on stock intercoolers and stock fuel pump - although as said, you are getting close to the limits of them.
a stock s4 clutch will not last long with 400bhp.
ko4 turbos
gut precats
catback exhaust
injectors
remap
rs4 clutch
http://www.MRCtuning.com
- GrimReaper
Mine should set me back £3k by the time i'm done which covers KO4's, RS4 intake pipes, RS4 clutch, injectors, fuel pump, RS4 IC's, custom MRC map. Exhaust already been sorted although doing bigger down pipes. All work apart from the map i'm doing myself (including pulling the engine) so save a fair bit of labour charge which i just couldn't afford on top of the upgrades.
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
Blue_Thunder
- Top Gear
Clive
MilkybarKid
Users browsing this forum: No registered users and 83 guests
