What is your peak MAF reading?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
S2tuner
Trader (Expired)
Post by S2tuner » Fri Jun 01, 2007 8:40 pm
Franck has around 420g/s, lucas around 485 I think... hard to say for L, because ECUx has never worked on his car, but reading it straight off the ECU was right around 485g/s...
okkim
Post by okkim » Fri Jun 01, 2007 8:54 pm
Where does that 360.8 g/s limit come from? The ECU apparently can understand more?
S2tuner
Trader (Expired)
Post by S2tuner » Fri Jun 01, 2007 8:55 pm
The limit only comes from the VAG protocol and the way the measured data is carried through the standard vag protocol. If you use a different protocol that grabs the data straight from the ECU's RAM, then you can read anything the ECU is registering.
S4TAN
Post by S4TAN » Fri Jun 01, 2007 10:28 pm
Mihnea - if the S4 MAF sensor can only measure up to 335g/s does this equate to a limiting factor for what the ecu can request of the engine/dictate to the engine in terms of fueling/timing/boost etc? In other words: with a stock S4 MAF the ecu will at most see 335g/s air mass/flow and NEVER anything above that - so the ecu will only ask for the max fuel/timing/boost appropriate to 335g/s air mass/flow??
Deus ex machina
jeffw
Post by jeffw » Sat Jun 02, 2007 4:09 pm
My understanding is that after 335g/s the default map takes over so you don't get the spot on fueling that you would get with the MAF reading but it still keeps producing more power...bit like when you disconnect the MAF to test if it's bad or not. The best solution would be to fit a RS4 MAF but you need the Airbox, pipe, intake etc etc so I never bothered.
ZeroK66
Post by ZeroK66 » Sun Jun 03, 2007 2:26 am
ZeroK66 wrote:Apparently I max the RS4 MAF sensor :)
Just what doug told me??
S4TAN
Post by S4TAN » Sun Jun 03, 2007 11:43 am
Ok - makes sense. I'll have to find out at what point in the rev range i hit the 335g/s limit ...
Deus ex machina
jeffw
Post by jeffw » Sun Jun 03, 2007 5:27 pm
to give you an idea here is my peak g/s
234.77 2880 102.06 100 12
235.07 3000 132.72 100 9
235.37 3160 187.36 100 6
235.68 3320 232.64 100 3.8
235.98 3560 239.19 100 3
236.28 3720 243.61 100 4.5
236.58 3960 255.75 100 3.8
236.89 4200 270.25 100 2.3
237.2 4400 283.61 100 3.8
237.52 4640 296.92 100 4.5
237.85 4840 307.64 100 6
238.17 5080 316.17 100 9.8
238.53 5280 323.33 100 9.8
238.86 5480 333.94 100 11.3
239.23 5720 335.36 100 10.5
239.59 5920 335.36 100 10.5
239.95 6120 335.36 100 11.3
240.33 6320 335.36 100 11.3
240.7 6520 335.36 100 15 3.73
Which is 418+ BHP from about 5500 rpm to over 6500
Nige_RS4
Post by Nige_RS4 » Sun Jun 03, 2007 5:37 pm
Minhea, coud you post your current MAF log so I can compare it to mine - I max the RS4 MAF out at around 6500rpm.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
S2tuner
Trader (Expired)
Post by S2tuner » Sun Jun 03, 2007 5:41 pm
Nige, you don't max it out, you only max what vag com can read out ;)
I'll dig some logs up and post them but they're still on my old laptop (I changed laptops 2 weeks ago)...
Nige_RS4
Post by Nige_RS4 » Sun Jun 03, 2007 5:57 pm
Sorry, that's what I meant to say!
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
DavidT
Post by DavidT » Sun Jun 03, 2007 7:48 pm
S2tuner wrote:Nige, you don't max it out, you only max what vag com can read out ;)
Bout time you had a new laptop :nodder: :lol:
I swapped to an RS4 maf which maxes out around 350 (jumps higher just after gearchanges though)
S2tuner
Trader (Expired)
Post by S2tuner » Sun Jun 03, 2007 11:49 pm
Come on David, I was in love with my old laptop, the display on it was sooooo good... and now I'm kicking myself for not buying a 20" screen one, only a 17" widescreen which sucks in comparison with the old one...
GrahamS4
Post by GrahamS4 » Tue Jun 05, 2007 10:17 pm
My typical max maf reading is 260 (repeatable), however in my logs from the other month I have a 269.81 but I have never seen it that high apart from that one occassion. Only ever done a few logging sessions though.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
DavidT
Post by DavidT » Tue Jun 05, 2007 11:00 pm
S2tuner wrote:Come on David, I was in love with my old laptop, the display on it was sooooo good... and now I'm kicking myself for not buying a 20" screen one, only a 17" widescreen which sucks in comparison with the old one...
I know you loved it mate. Biggest screen I'd seen on a lappy :shock: I reckon you need another 20" one at least, what with all those numbers & maps :lol: Has the new one got an 8 hour battery and a 750gb disc?
