Which diverter valves are you using?
Which DVs?
Stock
9
18%
710N
27
54%
Forge 006
2
4%
Forge 007
4
8%
Bailey
3
6%
Hyberboost original
3
6%
Hyperboost compact
0
No votes
Other (please specify)
2
4%
Total votes: 50
s4woody
Post by s4woody » Mon Mar 19, 2007 8:22 pm
slightly off topic but possibly relevent..MarkB has deleted his 249N valve which i believe electronically restricts the DV's from working normally..?
he says he can now hear his valves working so i think it would be good to get some1 that has none OEM valves to try this to see if they work better like his 710's are..just a thought..
GARTH ROAD MOT CENTRE LTD
020 83353032
davs4
Post by davs4 » Mon Mar 19, 2007 8:36 pm
At what BHP do the 710N's become ineffective??
MarkB
Post by MarkB » Mon Mar 19, 2007 10:03 pm
s4woody wrote:slightly off topic but possibly relevent..MarkB has deleted his 249N valve which i believe electronically restricts the DV's from working normally..?
I've got Baileys.
I can't get over how well the car is running now, but I've done quite a few things to it recently. Each doing a little bit towards the better running
Mark
s4woody
Post by s4woody » Mon Mar 19, 2007 11:59 pm
thats what i did and managed good power on the dyno..even with duff lambda,s..
020 83353032
S4TAN
Post by S4TAN » Tue Mar 20, 2007 12:38 am
I've got Hyperboost HX standard size DVs, but with uprated Forge blue springs - serviced pretty regularly.
Have new 710Ns as well, and tried them on the car a couple of times, but i prefer the feel of the car with the Hyperboosts, especially on gear changes when on boost (mine seem to open smoothly and shut quickly) ... I also have the N249 delete ...
As an aside - i did some experimentation on the 710Ns by repeatedly pushing on the piston to open the valve and letting it snap shut - there were a few times when it didn't snap shut properly and stayed slightly open (the piston seemed to close at a slight angle - not flush with the valve aperture) - you could blow through the valve - in effect a boost leak! ... it would then close again properly after the next time it was pushed open.
When I repeated the experiment with the Hyper HX's they snapped completely shut every single time without exception, creating an air-tight seal (couldn't blow through the valve at all) - they also seemed to snap shut quicker than the 710Ns ...
Given the amount of times your DVs are opening and shutting during an average journey I thought i'd go with the HXs ...!
More expensive yes - but well worth it IMHO ... 8)
Deus ex machina
derdle
Post by derdle » Tue Mar 27, 2007 10:16 am
Forge on mine...dunno which ones though...they were on the car when I bought it. Reminds me, it must be time to replace the pistons and seals.
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
lengster1
Post by lengster1 » Tue Mar 27, 2007 10:54 am
Forge on mine also,took them off last night,both operating smoothly and sealing when closed and they havent been serviced for two years,mainly because the car ran perfect until recently,does anyone know were i can get hold of a service kit v quickly?Seems rude not to do it while theyre off!
derdle
Post by derdle » Tue Mar 27, 2007 11:02 am
Lengster1...give Forge a call:
Phone: +44 1452 380999
Fax: +44 1452 386333
email: info@forgemotorsport.co.uk
Forge Motorsport
1A Ashville Trd Est
Bristol Road
Gloucester
GL2 5EU
Paul
lengster1
Post by lengster1 » Tue Mar 27, 2007 9:38 pm
Derdle your an absolute star
buzzard
Post by buzzard » Mon Apr 02, 2007 10:44 pm
forge on mine (all i know is that they're black and them little fecking pipe clips are enough to make you chuck yourself off the nearest cliff!!!)
one of the first things i did to the car
i get them checked when i have the car serviced
S4 B5 long gone
S4 B8 Stage 2
lengster1
Post by lengster1 » Tue Apr 03, 2007 11:20 pm
Worth keeping an eye on the vac pipe especially near the right hand dv (as you look at the engine) as its hard to route it so it doesnt rub on the throttle body and wear a little hole through it as mine did!
