Which diverter valves are you using?
slightly off topic but possibly relevent..MarkB has deleted his 249N valve which i believe electronically restricts the DV's from working normally..?
he says he can now hear his valves working so i think it would be good to get some1 that has none OEM valves to try this to see if they work better like his 710's are..just a thought..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
I've got Baileys.s4woody wrote:slightly off topic but possibly relevent..MarkB has deleted his 249N valve which i believe electronically restricts the DV's from working normally..?
I can't get over how well the car is running now, but I've done quite a few things to it recently. Each doing a little bit towards the better running
Mark
I've got Hyperboost HX standard size DVs, but with uprated Forge blue springs - serviced pretty regularly.
Have new 710Ns as well, and tried them on the car a couple of times, but i prefer the feel of the car with the Hyperboosts, especially on gear changes when on boost (mine seem to open smoothly and shut quickly) ... I also have the N249 delete ...
As an aside - i did some experimentation on the 710Ns by repeatedly pushing on the piston to open the valve and letting it snap shut - there were a few times when it didn't snap shut properly and stayed slightly open (the piston seemed to close at a slight angle - not flush with the valve aperture) - you could blow through the valve - in effect a boost leak! ... it would then close again properly after the next time it was pushed open.
When I repeated the experiment with the Hyper HX's they snapped completely shut every single time without exception, creating an air-tight seal (couldn't blow through the valve at all) - they also seemed to snap shut quicker than the 710Ns ...
Given the amount of times your DVs are opening and shutting during an average journey I thought i'd go with the HXs ...!
More expensive yes - but well worth it IMHO ...
Deus ex machina
Forge on mine...dunno which ones though...they were on the car when I bought it. Reminds me, it must be time to replace the pistons and seals.
Paul
Paul
Huge Grin
If you dont "do it now" you never will.
Huge Grin
Lengster1...give Forge a call:
Phone: +44 1452 380999
Fax: +44 1452 386333
email: info@forgemotorsport.co.uk
Forge Motorsport
1A Ashville Trd Est
Bristol Road
Gloucester
GL2 5EU
Paul
Forge Motorsport
1A Ashville Trd Est
Bristol Road
Gloucester
GL2 5EU
Paul
Huge Grin
Huge Grin
