New brakes............
NotNormal
Post by NotNormal » Tue Mar 20, 2007 4:25 pm
............have been ordered, should be here on friday 8)
RS4 Setup but with plan discs and braided line's allround
365 floating disc + caliper (Custom).jpg (79.45 KiB) Viewed 1618 times
MarkB
RE: New brakes............
Post by MarkB » Tue Mar 20, 2007 4:30 pm
How did you manage to get plain disc's. Have you gone RS6 on the disc? You'll need the caliper brackets to suit...
Are they being fitted for you by the supplying company?
Mark
NotNormal
Re: RE: New brakes............
Post by NotNormal » Tue Mar 20, 2007 4:47 pm
MarkB wrote:How did you manage to get plain disc's. Have you gone RS6 on the disc? You'll need the caliper brackets to suit...
They'll be fitted by Quatronics, they're the supplier.
Disc's are Phaeton one's ;). I don;t like cross drilled disc's as i seem to crack them, well i did on the Evo with the 330mm AP 6 pot's
If it needs bracket's then i presume that Quatronics will either have them made or order (if poss) accordingly
MarkB
RE: Re: RE: New brakes............
Post by MarkB » Tue Mar 20, 2007 5:12 pm
Ah! the Phaeton ones... pictures will be good please
Mark
david7m
Post by david7m » Tue Mar 20, 2007 5:36 pm
So its not the disc's in the original pic then?
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
NotNormal
Re: RE: Re: RE: New brakes............
Post by NotNormal » Tue Mar 20, 2007 10:46 pm
MarkB wrote:Ah! the Phaeton ones... pictures will be good please
I will once they land ;)
As soon as they arrive i'll get on it :D
david7m wrote:So its not the disc's in the original pic then?
No not the disc's in the pic - hence the bit in the first post about 'RS4 Setup but with plan discs and braided line's allround' :lol: :P
philipwalker
RE: Re: RE: Re: RE: New brakes............
Post by philipwalker » Wed Mar 21, 2007 9:12 am
Puzzeled why you went for the Phaeton 364x32 mm discs rather than the cheaper 335x34mm plain RS6 discs with custom caliper mounts ?
The V8 RS4 discs are cast with the holes in rather than drilled, they do crack but only when worn close to wear limits
http://www.pwmotorsport.com
PW Motorsport
01437 563929
NotNormal
Re: RE: Re: RE: Re: RE: New brakes............
Post by NotNormal » Wed Mar 21, 2007 10:58 am
philipwalker wrote:Puzzeled why you went for the Phaeton 364x32 mm discs rather than the cheaper 335x34mm plain RS6 discs with custom caliper mounts ?
Because the 335's aren't 364's - i like'd the feel of the RS4's brakes when i took one out so i decided to have thm on my car. I didn't like the feel of the same caliper but with smaller discs on th RS6 when i took that out . :)
philipwalker wrote:The V8 RS4 discs are cast with the holes in rather than drilled, they do crack but only when worn close to wear limits
That's as maybe, but, the AP disc's are manurfactured in the same way and on a smaller(slightly), lighter more powerfull car (Evo6 RS) i still managed to crack the disc's and they were 'as new'.
Only 0.14mm wear on both font disc's according to AP Racing.
And yes, they were bedded in correctly - warmed up gently and cooled correctly on evry occasion ! :(
With this on mind, why would i risk an extra bill or create more warraty issues by chancing having the RS4 drilled disc's when i'm more than happy with the Phaeton versions?? :?
........ohh and they match the rear plain disc's too now :oops: :)
MarkB
Post by MarkB » Wed Mar 21, 2007 11:30 am
I think Philip meant to say 365mm RS6 disc's. The phaeton disc's are thinner and slightly smaller diameter. The RS6 disc's probably didn't feel as good because of the extra weight or may have been worn.
Mark
philipwalker
RE: Re: RE: Re: RE: Re: RE: New brakes............
Post by philipwalker » Wed Mar 21, 2007 2:24 pm
Oops typo, thanks for that Mark
PW Motorsport
01437 563929
Corey
Post by Corey » Wed Mar 21, 2007 4:20 pm
Phaeton discs are floating discs (as in the neu RS4) but are not cross drilled, they measure 365x34mm, anyone care to argue?
Corey
MarkB
Post by MarkB » Wed Mar 21, 2007 4:43 pm
Nope, pictures pictures please...
Mark
Corey
Post by Corey » Wed Mar 21, 2007 5:06 pm
The Phaeton disc is the one on the right
Corey
david7m
Post by david7m » Wed Mar 21, 2007 5:08 pm
That seems a lot smaller!
philipwalker
Re: RE: Re: RE: Re: RE: Re: RE: New brakes............
Post by philipwalker » Wed Mar 21, 2007 6:57 pm
Corey wrote:Phaeton discs are floating discs (as in the neu RS4) but are not cross drilled, they measure 365x34mm, anyone care to argue?
Do you care to supply a part number?
I am unable to find a 365 mm disc for the Phaeton in Ekta not that 1 mm matters that much. Just a matter of principal.
PW Motorsport
01437 563929
