RS4 Setup but with plan discs and braided line's allround
New brakes............
............have been ordered, should be here on friday
- Attachments
- 365 floating disc + caliper (Custom).jpg (79.45 KiB) Viewed 1596 times
RE: New brakes............
How did you manage to get plain disc's. Have you gone RS6 on the disc? You'll need the caliper brackets to suit...
Are they being fitted for you by the supplying company?
Mark
Re: RE: New brakes............
They'll be fitted by Quatronics, they're the supplier.MarkB wrote:How did you manage to get plain disc's. Have you gone RS6 on the disc? You'll need the caliper brackets to suit...
Disc's are Phaeton one's
If it needs bracket's then i presume that Quatronics will either have them made or order (if poss) accordingly
RE: Re: RE: New brakes............
So its not the disc's in the original pic then?
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat
Re: RE: Re: RE: New brakes............
I will once they landMarkB wrote:Ah! the Phaeton ones... pictures will be good please
As soon as they arrive i'll get on it
No not the disc's in the pic - hence the bit in the first post about 'RS4 Setup but with plan discs and braided line's allround'david7m wrote:So its not the disc's in the original pic then?
philipwalker
- 5th Gear
RE: Re: RE: Re: RE: New brakes............
Puzzeled why you went for the Phaeton 364x32 mm discs rather than the cheaper 335x34mm plain RS6 discs with custom caliper mounts ?
The V8 RS4 discs are cast with the holes in rather than drilled, they do crack but only when worn close to wear limits
Re: RE: Re: RE: Re: RE: New brakes............
Because the 335's aren't 364's - i like'd the feel of the RS4's brakes when i took one out so i decided to have thm on my car. I didn't like the feel of the same caliper but with smaller discs on th RS6 when i took that out .philipwalker wrote:Puzzeled why you went for the Phaeton 364x32 mm discs rather than the cheaper 335x34mm plain RS6 discs with custom caliper mounts ?
That's as maybe, but, the AP disc's are manurfactured in the same way and on a smaller(slightly), lighter more powerfull car (Evo6 RS) i still managed to crack the disc's and they were 'as new'.philipwalker wrote:The V8 RS4 discs are cast with the holes in rather than drilled, they do crack but only when worn close to wear limits
Only 0.14mm wear on both font disc's according to AP Racing.
And yes, they were bedded in correctly - warmed up gently and cooled correctly on evry occasion !
With this on mind, why would i risk an extra bill or create more warraty issues by chancing having the RS4 drilled disc's when i'm more than happy with the Phaeton versions??
........ohh and they match the rear plain disc's too now
I think Philip meant to say 365mm RS6 disc's. The phaeton disc's are thinner and slightly smaller diameter. The RS6 disc's probably didn't feel as good because of the extra weight or may have been worn.NotNormal wrote:Because the 335's aren't 364's - i like'd the feel of the RS4's brakes when i took one out so i decided to have thm on my car. I didn't like the feel of the same caliper but with smaller discs on th RS6 when i took that out .philipwalker wrote:Puzzeled why you went for the Phaeton 364x32 mm discs rather than the cheaper 335x34mm plain RS6 discs with custom caliper mounts ?![]()
Mark
philipwalker
- 5th Gear
RE: Re: RE: Re: RE: Re: RE: New brakes............
Oops typo, thanks for that Mark
- Corey
Phaeton discs are floating discs (as in the neu RS4) but are not cross drilled, they measure 365x34mm, anyone care to argue?
Corey
That seems a lot smaller!
philipwalker
- 5th Gear
Re: RE: Re: RE: Re: RE: Re: RE: New brakes............
Do you care to supply a part number?Corey wrote:Phaeton discs are floating discs (as in the neu RS4) but are not cross drilled, they measure 365x34mm, anyone care to argue?
I am unable to find a 365 mm disc for the Phaeton in Ekta not that 1 mm matters that much. Just a matter of principal.
