I've broke my car :(
Yeah - I knew the flange on the downpipes would need changing, but this is not a huge problem.
I had a full custom exhaust made up by RS Fabrications... the fact that Doug has the exact same setup put on his car says it all. Its awesome. I hope that RS6 turbos will bolt onto my tubular manifolds.
Where is MRC... they can answer all of these questions.
Bl00dy KKK tubos... I should have gone down the garrett route!! That is what you should be doign... would have to do manifolds then, either GT25's or 28RS's... mmm
So what brand do you recommend if Garretts are unreliable and KKKs are hairdryers?
2001 Silver S4 Avant
The KKK thing was humour, although K04s are still relatively small in size (I get 1 bar of boost at 2400 RPM in 6th gear when going WOT at 2000).
IMHO Garrett's aren't very reliable, especially when a hose pops off and you get a leak, and the turbo thus runs a higher pressure ratio than what it was meant to run initially.
In that respect, I'm not very keen on using Garretts...
Mihnea
Mihnea
Dippy wrote:So what brand do you recommend if Garretts are unreliable and KKKs are hairdryers?
Why do we never hear to scoobies and evos etc popping turbos? I hear of gradual wear and them needing replacement after a long time... but never bent shafts etc? Is it simply that they are larger single turbos? Rather than the bi-turbo engines with these peepee little turbos?
QuantumJohn
Does the larger single turbo being more reliable theory also stand for the S2/RS2 turbos?ZeroK66 wrote:Why do we never hear to scoobies and evos etc popping turbos? I hear of gradual wear and them needing replacement after a long time... but never bent shafts etc? Is it simply that they are larger single turbos? Rather than the bi-turbo engines with these peepee little turbos?
John
You did this on purpose didnt you?? So when I visit you are faster... sod!
Users browsing this forum: No registered users and 180 guests
