I've broke my car :(
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
MarkB
Post by MarkB » Wed Mar 07, 2007 4:34 pm
That makes it clearer, Thanks
So Leon would need to get his tubulars modified rather than sell and get a new set if he wanted to go full RS6
Mark
viperbl
Post by viperbl » Wed Mar 07, 2007 4:44 pm
MarkB wrote:So Leon would need to get his tubulars modified rather than sell and get a new set if he wanted to go full RS6
My understanding was the downpipes were the problem, so they would need a new flange on them if RS6 turbo's where used, or, larger downpipes and made to fit the exhaust.
RS4 B5 Saloon8) with 750+ bhp :D
ZeroK66
Post by ZeroK66 » Wed Mar 07, 2007 5:19 pm
Yeah - I knew the flange on the downpipes would need changing, but this is not a huge problem.
I had a full custom exhaust made up by RS Fabrications... the fact that Doug has the exact same setup put on his car says it all. Its awesome. I hope that RS6 turbos will bolt onto my tubular manifolds.
Where is MRC... they can answer all of these questions.
DavidT
Post by DavidT » Wed Mar 07, 2007 5:22 pm
MRC is in Banbury ;)
I suspect Doug is there, doing real work :lol:
viperbl
Post by viperbl » Wed Mar 07, 2007 6:52 pm
I have the turbos in my hand!! Only 4 weeks and 3 days laters! :lol:
Ok, one of the turbos, on the hot side has lost a blade and another 3 or so have been chipped, also, the shaft is bent ... ill get photos online tomorrow.
ZeroK66
Post by ZeroK66 » Wed Mar 07, 2007 7:29 pm
Bl00dy KKK tubos... I should have gone down the garrett route!! That is what you should be doign... would have to do manifolds then, either GT25's or 28RS's... mmm
viperbl
Post by viperbl » Wed Mar 07, 2007 7:39 pm
ZeroK66 wrote:Bl00dy KKK tubos... I should have gone down the garrett route!! That is what you should be doign... would have to do manifolds then, either GT25's or 28RS's... mmm
I am talking to Vagmotorsport.ca as we speak :o lets see what they say about their kit on my car ...
S2tuner
Trader (Expired)
Post by S2tuner » Wed Mar 07, 2007 9:49 pm
Do Garretts? And what happens when you have a boost leak? Bearings go kaboom and that's it, buy a pair of new CHRA's. That's the only one thing I'm scared of with Garretts. They have been known for not being reliable at all when pushed past their max, as for instance when you have a boost leak.
Dippy
Post by Dippy » Thu Mar 08, 2007 2:16 pm
So what brand do you recommend if Garretts are unreliable and KKKs are hairdryers? :)
2001 Silver S4 Avant
S2tuner
Trader (Expired)
Post by S2tuner » Thu Mar 08, 2007 2:48 pm
The KKK thing was humour, although K04s are still relatively small in size (I get 1 bar of boost at 2400 RPM in 6th gear when going WOT at 2000).
IMHO Garrett's aren't very reliable, especially when a hose pops off and you get a leak, and the turbo thus runs a higher pressure ratio than what it was meant to run initially.
In that respect, I'm not very keen on using Garretts...
Mihnea
Dippy wrote:So what brand do you recommend if Garretts are unreliable and KKKs are hairdryers? :)
ZeroK66
Post by ZeroK66 » Thu Mar 08, 2007 3:23 pm
Why do we never hear to scoobies and evos etc popping turbos? I hear of gradual wear and them needing replacement after a long time... but never bent shafts etc? Is it simply that they are larger single turbos? Rather than the bi-turbo engines with these peepee little turbos?
S2tuner
Trader (Expired)
Post by S2tuner » Thu Mar 08, 2007 3:32 pm
Bent shafts? that doesn't happen on KKK's very often either... at least not on K04s... what happened to Rich is probably due to the car bottoming out IMHO, not a representative example of what happens to all K04 turbos...
QuantumJohn
Post by QuantumJohn » Thu Mar 08, 2007 3:36 pm
ZeroK66 wrote:Why do we never hear to scoobies and evos etc popping turbos? I hear of gradual wear and them needing replacement after a long time... but never bent shafts etc? Is it simply that they are larger single turbos? Rather than the bi-turbo engines with these peepee little turbos?
Does the larger single turbo being more reliable theory also stand for the S2/RS2 turbos?
John
viperbl
Post by viperbl » Thu Mar 08, 2007 3:59 pm
Getting there ...
KO4's sent off to America for the KO4/RS6 Hybrid treatment ...
MRC FMIC/injectors and fuel pump on there way.
I am also going to get my current manifolds ported/polished and coated.
Lets see what power MRC can get out of my car after all is installed ... 8)
ZeroK66
Post by ZeroK66 » Thu Mar 08, 2007 4:51 pm
You did this on purpose didnt you?? So when I visit you are faster... sod! :P
Users browsing this forum: No registered users and 143 guests
