S4 service
- shineydave
don't make me laugh, my lips are chapped
- shineydave
that's all dependant on the quality of the suit. if indeed it is a PVC gimp suit then vaseline will be fine but a genuine rubber gimp suit should not be lubricated with vaseline, or indeed any petrolium based lubricant as the petrol content will rot the rubber sure as eggs are eggs.
that's why you should never lubricate "o" rings and seals with vaseline, they should always be lubricated with the medium that they will be sealing
- shineydave
embryos as well
Absolutely spot-on. Most natural rubbers will be attacked by any petrochemical-based product. Best thing for rubber or latex is a silicon based oil/grease or water based lubricant such as K-Y jelly (depending on the application).shineydave wrote:that's all dependant on the quality of the suit. if indeed it is a PVC gimp suit then vaseline will be fine but a genuine rubber gimp suit should not be lubricated with vaseline, or indeed any petrolium based lubricant as the petrol content will rot the rubber sure as eggs are eggs.
Talcum powder (the cosmetic/baby type) is also bad for latex as it contains compounds that can attack the rubber and/or support bacteria/yeast growth. You should use French chalk instead.
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
engine will be seriousley affected if you let loose all the coagulated burnt sh1t in .... dont forget the turbos bearing surface is supported by oil ..... at a thickness of mere thou's.......MarkB wrote: The only way I would flush an engine is to do 2 oil changes close together. Diluting the dirty oil and crud into the new clean oil.
If any of our engines are in this sort of state then I'd be expecting a large bill before long...
looks like dave's had a few oil changes in his rubbergimp suit before now~shineydave wrote: should always be lubricated with the medium that they will be sealing
is it yr regular shopping attire dave....?
- shineydave
i'm not actually a gimp suit wearing freak of nature, i just help them out on weekends.................oh, and when they're particularly busy
- shineydave
IT'S NOT PVC!!!!!
oops, did i say that out loud?
- shineydave
certainly not, i'm in Bradford, the curry capital of the northern hemisphere
Users browsing this forum: Majestic-12 [Bot] and 73 guests
