VAG-COM 607..
VAG-COM 607..
Anyone in Wiltshire got this and can run a test on my car to see if they can access Sat Nav? I have the older VAG-Com version and before I go and buy a newer copy, I wanted to check it worked on the functions that I cannot currently access.
Thanks,
Rob
Thanks,
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: VAG-COM 607..
Rob. Not quite Wiltshire but I work in Theale (J12 of the M4). If you are in that neck of the woods I'd be happy to help.
RE: VAG-COM 607..
You can download the latest version from their website.
Re: RE: VAG-COM 607..
and it will work if you have a recent genuine ROSS-TECH lead...DavidT wrote:You can download the latest version from their website.
Mark
Thanks Mark, I must have missed something then ?MarkB wrote:and it will work if you have a recent genuine ROSS-TECH lead...DavidT wrote:You can download the latest version from their website.
RE: Re: RE: VAG-COM 607..
If Rob is running version 409 I would think he needs a newer ROSS-TECH lead or he's using a generic lead.
Mark
Yeah you need a Ross-Tech "HEX" lead to run later than v4.
And one should buy a genuine lead, great value for money
Yep, I have the old "dumb" lead. I wanted to check the newer VAG-com version worked the sat-nav and other functions before splashing out...
Rob
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
- PetrolDave
Re: RE: Re: RE: VAG-COM 607..
607.3 and a HEX-COM+CAN lead lets me access all the controllers (including both engine ECUs [the RS4 has one per bank], RNS-E and phone) on my 2006 RS4.Tartan_Rob wrote:Yep, I have the old "dumb" lead. I wanted to check the newer VAG-com version worked the sat-nav and other functions before splashing out...
Rob
RE: Re: RE: Re: RE: VAG-COM 607..
HEX-COM+CAN is the serial port on the laptop right?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Re: RE: Re: RE: Re: RE: VAG-COM 607..
Not sure, I think all the newer ones are USB Rob.Tartan_Rob wrote:HEX-COM+CAN is the serial port on the laptop right?
RE: Re: RE: Re: RE: Re: RE: VAG-COM 607..
Your right Rob
Hex-com + can is serial port. check ross-tech site to be sure
Mark
I have hex-com+CAN brand new lead and mine is USB.
- PetrolDave
You can order HEX-COM+CAN which is for a serial port, or the more expensive HEX-USB+CAN which is for USB.DavidT wrote:Not sure, I think all the newer ones are USB Rob.Tartan_Rob wrote:HEX-COM+CAN is the serial port on the laptop right?
Or even the cheaper micro-CAN - but this is for CAN ONLY cars like the Golf V, 8P A3, 8J TT, etc.
Or if you don't want any CAN capability the KEY-COM for a serial port, or the more expensive KEY-USB for USB.
http://www.ross-tech.com/Merchant2/merc ... ode=VAGCOM
